Delco-loc II installation
Old 09-22-2014, 09:44 AM
roamaver's Avatar
Car: 1985 Iroc Z28
Engine: 5.7L TPI
So I've been thinking about installing this stock unit that came from what I believe was my old 94 z28, into my 85 Iroc.
I've been looking for reverse wiring adapters and am having trouble finding the adapter I need. So far I've found this one.
Amazon Amazon
This would be able to wire up to the current adapter I have connected to the stock 1985 harness (I believe)
But if you look at the rear picture of the deco unit there is another black 5 pin plug as well. I am having trouble finding a plug for this.
Has anyone installed one of these into their thirdgen before or has any input they could share?
Thanks in advance!
Old 09-22-2014, 09:59 AM
*84TA's Avatar
Car: 84 Trans Am
Re: Delco-loc II installation
This is what you need.
http://autoplicity.com/products/2369...12_21_pin.aspx
That is a bose radio. It will not work unless you install the whole bose system with the speakers that have built in amps. The radio does not have an amplifier. You will need a way to drive the speakers. As for the black plug with 5pins. It does not need to be hooked up, I believe that was for the steering wheel controls.
Old 09-22-2014, 10:03 AM
roamaver's Avatar
Car: 1985 Iroc Z28
Engine: 5.7L TPI
Great, thanks for all the info *84TA!
Old 09-27-2014, 10:21 AM
rstjet's Avatar
Any help on removing a Delco Loc II from a 91 Firebird?
Vintageracer
01-10-2020 05:33 PM
redmaroz
04-25-2017 07:14 AM
dennisbernal91z
Fabrication
29
03-02-2017 12:04 PM
gixxer92
09-01-2015 04:32 PM
86IROC112
08-17-2015 07:57 PM
Quick Reply: Delco-loc II installation
