UQ7 Questions
UQ7 Questions
I recently bought a 1986 Trans Am, and it came fully loaded from the factory with all the little goodies including the UQ7 speaker package. The problem is its missing its original subs. The previous owner gave me the the original front and side speakers along with the UT4 Radio, but said that when he bought the car the subs were already gone.
1.Due to the age of the car I have my doubts that I will be able to find OEM replacements so what would be a good alternative to the factory subs that have the same specs as the factory ones?
2.I am having this problem were the radio will change its station back and forth. How do i fix this?
3.Also where do I find the amp at?
p.s if anyone has OEM replacements for sale call me at 331-205-9916
Thanks for reading!!!!!!
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: UQ7 Questions
The amp is right behind the "glove box" pouch. You don't want to bother with the stock sub boxes, the speakers were really small. You could do better with some other type of aftermarket speakers, you can't see them anyway.
I have a left box only that I would be willing to sell, but the chances of finding a right only would be slim.
1 Post
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: UQ7 Questions
stock speakers were really poor quality, as mentioned there is no reason to bother with them. if they had decent aftermarket woofers it may have been but no body makes those that i have seen. i put aftermarket 6x9s in, they sound better and last longer
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: UQ7 Questions
Try member, my82roc,I think he has some stock subs for your UQ7 Sound System.I had mine rebuilt(reconned)
Car: 1984 Pontiac Firebird Trans Am
Engine: V8 5.0L HO (L69)
Transmission: B&W T5
Axle/Gears: 3.73 limited slip
Re: UQ7 Questions
You can find very small subwoofers in computer 2.1 sound systems and other home speakers. Just make sure they're 4 ohms. You can get these for nearly nothing.
I don't know how good or not they are though. But I suppose if they come from branded equipement, they should be allright.
I haven't found many aftermarket subs that would fit the original box at a decent price.
Car: 1988 Trans Am GTA
Engine: 5.7
