Front Speakers stopped working
I swapped the aftermarket Front speakers out for a OEM set. But they will not work. The previous owner cut the GM connectors, so i connected the old ones back. I used a diagram so i know that the wires are connected correctly, and i know that the speakers work because i tested them. My rear speakers work.
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: Front Speakers stopped working
Maybe the head unit decided to die all of a sudden. Ive had that happen to me twice with passenger side speakers completely going out and rear speakers the second time with no warning. Id start there if you happen to have a spare head unit you could test with.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Their is a speaker wire junction behind the radio for all the speakers,you may have unplugged them when you put the radio back in.It happened to me
This isn't my pic,but those wire junctions are in this area.
I just tried swapping out the units, but still no luck. everything is also plugged into the back of the radio, I do not see any junction. also the fronts stopped working after i swapped the aftermarket ones out. this car has so many electrical problems.
Engine: 5.0 EFI
Yea,I think just the cars with UQ7 system have that.I had taken a pic of that for future reference but I bought a new Computer Tower and the tech didn't download half my pics.
I'm glad you found the problem.
Engine: 5.0 EFI
Yep,I usually just adjust it down,You'll get used to it.
It's been so long since my UQ7 setup worked, I don't remember how it sounds. Lol
1992 Trans Am
05-10-2023 07:19 PM
db057
08-11-2015 10:11 PM
