Factory replacement speakers..
Car: 91 Z28 Coupe
Lokking to replace my speakers on my 91Z. I was able to find, and buy the AC Delco fronts. But I am having a difficult time locating the rears. The Delco part is 16040911. Has anyone had any luck in finding these?
Re: Factory replacement speakers..
They have been discontinued for a while. I checked a national NOS parts distributor and they did not have any. Try calling a local chevy dealer and I have them do a national inventory search. If they come up with nothing then you are out of luck
Car: 91 Z28 Coupe
Thanks for you help. Looks like I am stuck with modifying another speaker.
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
Alpine make oval speakers that are better quality direct replacements for both the front and rear speaks.
Key to the kickers are run them off an amplifier. I used bass blockers on the 4x6 and put 2 10 inch subs in as well. Ran everything off a 5 channel amp. Good balance of kids, highs and bass. I like it. Kickers like power.
Car: 91 Z28 Coupe
I probably should have mentioned that the car has the stock radio, and I plan on keeping it that way. So no amps or subs.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I was going to say that I have a set , BUT , their the 4 ohm version.You may have to have them reconed.
