newer gm radio fit in 1992 rs?
Car: 92 Camaro RS
Engine: 5.0L
Transmission: AUTO, 56k orig
the factory cd player in my rs doesnt work anymore.....does anyone know if this newer gm radio will fit into the car with little to no modifications? also harness connections etc? thanks http://www.ebay.com/itm/OEM-AC-DELCO-Factory-Original-GM-GMC-OLDSMOBILE-STEREO-RADIO-CD-PLAYER-w-FAN-/351518894938?fits=Model%3ACamaro&hash=item51d828ab5a&vxp=mtr
Car: 84 Trans Am
Re: newer gm radio fit in 1992 rs?
It will fit right in. The mounting tabs are a bit different but you shouldn't have a problem. I have one with a aux jack wired in if you are interested.
1 Post
Car: 1991 GTA
Engine: LB9
Physically it will fit with little issue(like *84TA said, the mounting tabs are a bit different but no big deal).
The plug is completely different however. I got around it(Not in my TA but another vehicle) was to get the plug out of the car I got the radio out of then reverse engineered the connections to my existing harness.
On the 92 its a direct fit even the plugs in the rear. I have done it on 5 different 3rd gens
There is a thread in here from a couple of months ago where someone did that exact upgrade and it had a lot of information about factory radio swaps.
Like tealman said, it should work fine.
EDIT: here it is... https://www.thirdgen.org/forums/car-...lco-radio.html
tapwr
10-10-2015 08:53 AM
