1991 Camaro RS: stereo single or double din?
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: 4 Speed Automatic
To me it looks like a double din,but on Sonic Electronix it (where I hope to buy my new one) is showing single dins. Am I wrong? It just looks so much taller than a single. It is the stock stereo,so there's no chance somebody swapped it to a double din.
Re: 1991 Camaro RS: stereo single or double din?
it is 1.5 din the after market does not support 1.5 din anymore ,thats why you see single din,there are kits that adapt those
1 Post
Car: 1991 GTA
Engine: LB9
So you can use a din with an adapter, or you can modify and stuff a double din in there.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
For single din...check out Humount mounting plates.
http://maptechenterprises.com/storef...&products_id=3
Car: 1991 Camaro RS
Engine: 305 TBI
Other options you can always modify your bezel, and make a double din fit.
That's what I did.
There are some 1.5 din stereos out there, but I know nothing about the quality of them. They are not from the normal companies. I remember someone posting one on there not too long ago, it was from a Jeep forum.
That's what I did.
The double din installs that I have seen in the Camaros look terrible. The trim has been cut and Im sure the wiring has all been jammed into the back. The HUmount looks great even though it forces you to use a single din radio. There are plenty of quality single dins out there.
I want to get the HUmount for my 91 but I have yet to find one that somone chose the yellow led. Its either yellow or white for me and Id rather have yellow IF if matches the factory yellow in the 90-92 Camaros. if not then white it is and I will figure out how to tint the led with some sort of semi transparent lens paper assuming it comes apart.
I was just throwing options out there.
1 Post
Car: 1991 GTA
Engine: LB9
Putting a double din in these cars is not plug and play.
You can get a wiring harness adapter, so I guess that part of the equation can be plug and play.
But due to the size of the radio opening(din 1.5), you have to do some modification to the bezel to get one to fit.
Good luck getting one of those HuMounts. The guy making them sucks at returning emails and I have heard of customers who paid for one and 2 months later havent received their kit. I emailed him back in Feb and I havent received a response back yet. I gave up and bought a regular install kit on Amazon.
Modifying the Bezel isn't too tough, see the link in my sig on how to do it.
You will need to also cut/modify the HVAC vents to get the larger deck to fit all the way back. I cut mine then used duct tape to basically mold a new duct the size I needed. Seems to be working.
