is this original or part of the P.O's audio system?
Hey guys, I just fixed my rotting floor pans. I found out that they rotted because the P.O fed his subwoofer wire from the battery through a hole in the firewall that normally had a plug in it. I saw the water trickle down directly to the spot that I just put fresh metal in. While I was under there I saw some questionable wiring that I'm wondering if it is even original or was it all part of his sound system.
is the white connector, red and blue inline fuses, and little red connector original or part of a sound system set up?
these relays say apex so I'm assuming they were for a sound system but would like to double check, they have two blue wires that run into the part in the next pic.
here's where the apex relays wire into, this is directly behind the driver's side kick panel. what is this?
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: is this original or part of the P.O's audio system?
While I have no idea what is bolted behind your kick panel, I can say for sure that none of the rest is original.
thanks, that cleared up the birds nest of wires I want to get rid of but now I am unsure of what to do with the part behind the kick panel since those relays are wired to the part. I feel like that part is original but I could be wrong.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
I pulled a dealer installed alarm out of my 89 that had a similar connector and pair of relays taped together in that same fashion (same brand, too...).
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Possibly, those two Blue wires look like they don't belong there.
Well after scoping it out today you guys are all 100% correct as usual, thanks for the help. Unfortunately removing all that is gonna have to wait, didn't expect to see this when I pulled the carpet up
Once I cut this out and weld the new pan in and sealed and get my new carpet and interior installed I will remove all that junk. Thanks again
Engine: 5.0 EFI
http://www.ebay.com/itm/AUTHENTIC-19...pXMKo0&vxp=mtr
If your serious about keeping the car ,this is a great tool
