wires from engine bay
i need to run a wire for a pressure sender and am amp from the engine bay to inside the car. are there any existing holes i could use before i drill one in a 89 trans am?
thanx
thanx
Re: wires from engine bay
There's probably a few empty spots in the C100 bulkhead connector that could be used by just buying the terminals and snapping them into the open holes. Or there's a LARGE opening next to the steering column for the cruise control harness, plenty of room there even on cars with cruise to fish a couple extra wires through the existing grommet.
Axle/Gears: 10 Bolt 2.73 Open
I ran a power cable for my amplifier from a terminal near the battery (passenger side in my car), along the top of the inner fender, and to the grommet where the antennae cable enters the car.
Posts 223 - 248 have photos of it.
https://www.thirdgen.org/forums/memb...ew-1988-t.html
thanx
dave i'll check it out, need to run an amp wire, wideband O2 and boost sensor line.
