Not sure, but will it clear? IDEAS!
Old 10-22-2002, 12:43 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
I am doing a 383 swap for my old 305 tbi in my 91 RS. I have the stock flat hood on right now, but want to know if I can clear this new set up with the stock hood?
A little information:
It's a 383 with dart heads and a dart intake (tall intake, like a victor jr.).
I am running a 800cfm holley DP.
Can I clear a low profile cleaner?
If not, I was thinking about the butterfly scoop (for single carbs) with a hole (perfectly cut) in the stock hood coming out the top, would this look okay>?
How many problems would I run into with this air cleaner? Would I have to worry about s-h-i-t going inside the carb with this intake mod?
Any pics of something like this?
Can anyone photoshop something like this?
Old 10-23-2002, 09:22 AM
TBI305Camaro's Avatar
doubt it will fit unless you run a tiny element. The hood scoop should work fine and with some type of filter nothing will get into the carb...maybe on the motor but itll be ok
Old 10-28-2002, 12:13 AM
Kingtal0n's Avatar
Car: 240sx
Engine: whatever works
Transmission: 4l80e this year
Axle/Gears: 3.512
<b>If not, I was thinking about the butterfly scoop (for single carbs) with a hole (perfectly cut) in the stock hood coming out the top, would this look okay>?
</b>
as long as you dont get cought out in the rain.
Seriouselly, I had a Victor Jr. single plane (with airgap) on my engine and it fit fine under the stock hood with a 2" dropbase aircleaner. I used a 14X3 with 2" dropbase and an Xtreme lid to feed out the top so when i got my cowl it would feel better.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
83 Crossfire TA
01-03-2016 01:26 PM
Stryker412
09-07-2015 09:11 AM
Jetmeck
09-04-2015 12:29 AM
andy74
09-03-2015 08:41 AM
Quick Reply: Not sure, but will it clear? IDEAS!
