Fuel injector cleaner in a carb? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 05-16-2003, 08:14 AM   #1
I just put in fuel injector cleaner in the tank of my 84 trans am (carb). I wasn't really thinking that it wasn't fuel injected, will this hurt my car at all? I used STP Fuel Injector cleaner, right after I changed my oil.
Trans-it is offline vBGarage Page   Reply With Quote
Old 05-16-2003, 09:44 AM   #2
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
No problem. They're basically the same stuff, designed to loosen up crud in your fuel tank, plug the pick-up screen, and clog the fuel filter...
five7kid is offline vBGarage Page   Reply With Quote
Old 05-16-2003, 06:32 PM   #3
so then should i never use those products? I've heard that they're pointless from some, but never really bad. I guess I'll just change the fuel filter now.
Old 05-19-2003, 01:56 PM   #4
five7kid's Avatar
Engine: LS1/LQ4
No, not really. I had a bad experience with STP several years ago, that's all.
I use a small dose of fuel additive cleaner with every fill-up. If the car has sat around unused for any length of time, or poor quality gas used regularly (haven't heard of that type of problem recently), then adding a cleaner can do what I said above.
Old 05-22-2003, 01:01 AM   #5
Car: 1986 Pontiac Firebird S/E
Engine: LG4 TPI Conversion
Axle/Gears: 3.42 SLP Posi 10 Bolt
I use it frequently
I use it because it tends to do a better job than the carb/fuel inj stuff in a white bottle.
Look at it this way, it wouldn't be sold over the counter if it would do harm to a carb, otherwise there'd be even more law suits.
I like STP, but for about the same price you can also get Berryman B-12 Chemtool, which I feel is a better product. I usually put half the bottle in my COLD crank case and run it 5 minutes to flush the motor out before I change oil. The other half goes in the tank at about 1/2 tank.
86BirdSE is offline vBGarage Page   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Car hard to start bryan623 TPI 5 03-02-2016 10:12 PM
[MI] 1987 IROC Camaro 5.3/4L60E sweet_87_iroc Camaros for Sale 5 09-25-2015 11:01 PM
1989 iroc z28 camaro 5 speed manual 5500$ kyleb24 Camaros for Sale 2 08-15-2015 09:24 AM
Bogging at 40mph need help!! Infested Tech / General Engine 2 08-14-2015 06:25 PM
24lb bosch D3 fuel injectors Firechicken86 Engine/Drivetrain/Suspension Parts for Sale 0 08-12-2015 11:07 PM
Go Back   Third Generation F-Body Message Boards >
Tags
bad, car, carb, carbd, carbureted, carburetor, carburetors, cars, classic, cleaner, fuel, harm, hurt, injection, injector, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
