Post Your Carb'd Motor Pics
#1252
Car: '86 Trans Amvanian Frankenbird
Engine: 350 4bbl
Transmission: T5 4.03/.76
Re: Post Your Carb'd Motor Pics
I swear there's a motor in there somewhere.
Third carb. This spread bore Holley had an AMAZING sound, ran great, but wouldn't cooperate with the 700R4, so it was replaced with a square bore Holley. Then the transmission died...
#1253
Car: 88 Sport Coupe
Engine: LO5
Axle/Gears: 2.72 G80
deleted
#1257
you guys and your rubber fuel line, especially stuff running in such close proximity to the exhaust components. that's a fire waiting to happen. run as much hardline as you possibly can guys, and use rubber only for the connections, or spend a few extra dollars on some braided stainless or quality pushlock hose (like the aeroquip socketless hose) and some AN type fuel filters. that little plastic fuel filter has been known to burst. just don't want to see anyone's pride and joy burn up because of an oversight.
#1258
Car: 1987 sport coupe camaro
Engine: 355
Transmission: 5 speed
#1259
Car: 88 Sport Coupe
Engine: LO5
I love my clear distributor cap! Lol
#1261
Holley 4bbl, Edelbrock Intake, non computer controlled 65k dizzy etc...
Ready for spring cruisin!
If this board had a modded car of the month, Id submit mine!...lol (just kidding...There are some good looking set-ups on this site for sure!) Good job yall!
#1262
DonW that is a Sinister lookin 82-84 car! Blacks a Tough color to do, esp on these cars that have been beat to hell & back before most of Us owned ours...Yours is just Clean! Love the 85-87 wheels too, they Work
#1263
Thanks, Rob. Your engine up there looks like a beast! Looks great!
#1264
#1270
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
400 small block
Pretty clean 408 small block, 450 horse
#1274
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
900hp 565ci BBC
#1276
Just so you guys remember "the good ol' days" -
My 1958 Rambler American, 195 cu in, Carter YF carb, and Flash-o-Matic transmission. Even has the optional sun visors!
#1277
My 1984 transam freshly painted and dropped in
#1278
350 Vortec, Heddman headers, Edelbrock carb.
#1280
Car: 1988 Camaro
Engine: 383ci SBC
Just finished up my carb swap on my 1988 IROC.
383ci with Quick Fuel 750.
#1286
LT1 carbed
Some of these cars I am seeing are just unbelieveable, just magnificent
#1288
On the stand:
Before:
After, in the car:
My goal was old school and as simple as you can get! Anything not necessary to the function of this engine was removed from the engine compartment, which was a lot of wiring & hoses.
Before:
After, in the car:
#1292
#1294
Car: 1992 camaro rs 25th anniversary
Engine: 350 v8 small block
#1296
Car: Camaro Z28
Engine: 5.7L 350 V8
Transmission: 350 turbo transmission
She’s a work in progress we’re about to swap heads intake and carb for a Holley 700cfm
#1299
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
My latest. 385. Engine bay still needs cleaned up
#1300
Car: 1983 Pontiac Trans Am
Engine: 305 CI V8(LG4)
Transmission: T5 5-speed
Mine before engine was removed for rebuild. Daytona 500 pace car w/ LG4 and T5 trans. Undergoing heads/cam, and mechanical to hydraulic clutch conversion! Its a mess now, but will be really pretty when it's done!
