Post pics of your Edelbrock 1405/6 linkages
Old 03-16-2005, 02:26 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
so I can see how to connect this thing properly!
Old 03-16-2005, 01:59 PM
duz
duz's Avatar
Car: 82 Firebird
Engine: 5.0
Transmission: 3 speed auto
here 'ya go!
thats right; 10 cents worth of rubber hose going to a 3 dollar filter..
i guess the proper fitting that goes into the carb PN#8131 is backed up. i've been waiting for (no kidding) a month and a half for that and PN#8123 arrive. i've yet to start it with rubber line.
Old 03-16-2005, 02:01 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
cant see the pics.
Old 03-16-2005, 02:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I think he's more interested in the throttle linkage than the fuel line.
Old 03-16-2005, 08:36 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
this is correct but the picture would still come in handy i'm sure
Old 03-17-2005, 12:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If I hadn't just pulled the engine out of my car I'd go out and take a picture. What details are you looking for?
Old 03-18-2005, 01:54 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
any modification from the stock linkage to the carb linkage
Old 03-18-2005, 01:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That depends a lot on your intake. On something dimensionally similar to stock, like a regular Performer, you could probably run the stock cable brackets without any modification, or maybe with just a little bending. For anything taller, you'll need a different bracket. There doesn't seem to be anything available on the market that's a proper direct bolt-on solution though. There are a number of "universal-fit" cable brackets that can be made to work reasonably well, from companies like Spectre, Transdapt, etc., although they tend to be lightly constructed and are prone from flexing.
Old 03-18-2005, 04:26 PM
chevydude350ho's Avatar
Car: 90 Iroc-Z
Engine: carb'd 350
Transmission: built 700r4/3000 stall
My car was originally tpi, but i have a spectre bracket and it works pretty darn good except for the slight flexing of the bracket. Its nice that its adjustable, worked for the 1406 i had on it to break the cam in, also works good with my holly DP650. Then again i have a really stiff return spring since i have an aftermarket throttle cable that isn't teflon lined, so i have a stiff pedal, so thats probably why it moves a little. I paid 21.99 for mine at autozone.
Old 03-18-2005, 05:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The only thing you really have to watch for with the flexing is that you can't adjust the TV cable the way the books tell you to do it. The bracket will give a fair bit before there's enough tension for the TV cable mechanism to self-adjust.
Old 03-18-2005, 06:29 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
I have the edelbrock linkage bracket for vortec heads from my lasr tbi setup... any good?
Old 03-18-2005, 06:36 PM
Car: 90 Iroc-Z
Engine: carb'd 350
Yeah, i noticed that as well.
Old 03-18-2005, 11:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Worth a try at least.
Old 03-18-2005, 11:56 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I find it amusing that in all these posts there is only one pic.
Old 03-19-2005, 01:16 AM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
and it wasn't even anything I needed for my particular question
but yeah I assume I'll get it
aaron7
08-17-2016 06:02 PM
Chuck84TA
07-15-2016 09:05 PM
Mickeyruder
09-02-2015 02:45 PM
BlackphantomZ28
08-22-2015 01:00 PM
1985chevydude
08-20-2015 12:29 AM
Quick Reply: Post pics of your Edelbrock 1405/6 linkages
