anyone ever port and polish a carb?
Old 05-17-2006, 10:12 AM
gerard's Avatar
Car: 84 trans am
Just wanted to see if anyone had good results with p and p of a carb. I have a q-jet and deburred it and polished it didnt notice a change in power but a slight improvement in gas mileage.
Old 05-17-2006, 10:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
what parts did you port polish or deburr? The venturis? huh, figured that would be a bad thing as far as fuel mixing...?
Old 05-17-2006, 11:10 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You don't really have to touch the venturis to make improvements, you can radius the entries into the throats, deburr the edges of the boosters, narrow the booster legs, etc.
Old 05-17-2006, 12:37 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
i've done it
nebu.
Old 05-17-2006, 01:00 PM
gerard's Avatar
Car: 84 trans am
Any hp improvments?
Old 05-17-2006, 01:13 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
my buttdyno hasn't noticed much of a difference. maybe a little.
Old 05-17-2006, 01:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
oh right, Tony'78Z I think is his name, try searching for a few posts by him. I think he put a 350 in a datsun 240z or something... anyway, in his sig he has a fair bit of info on that on his q-jet, very nice paint pictures as well.
Old 05-18-2006, 09:05 AM
firebirdjones's Avatar
porting and polishing carbs
I run an 850 dp holley on the chevelle and experimented with it. I cut off the choke housing, polished the venturies, boosters, and smoothed the transition into the top of the carb, and it looks much like the carb in the picture above. It was very labor intensive and time consuming, not worth the time and effort it my opinion, because you are still stuck with an old main body that doesn't have adjustable air bleeds, among other things.
In the end, I had the carb apart so many times at the race track for jet changes and what not, that eventually the screw holes started stripping out, The rear squirter was also stripped from removal and reinstall, it basically had met the end of it's life span so I ponied up and purchased a Pro Form main body, (had to go pro form since holley is not making an 850 main body available seperate, Yet anyway) it's a very slick main body that required no grinding/polishing and has adjustable air bleeds as well so it is more tuneable.
Once I had the jetting dialed in the car picked up about a tenth and almost 1 mph from it's previous best.
In my opinion, it's not worth all that effort when you can spend a measly $125 for a nice main body and be done with it,,,and it's better than anyone can do by hand.
With a Q-jet you are pretty much on your own though, as I am not aware of any aftermarket Q-jets that come this way,,which is too bad, I would like to try one on another car of mine if that were the case. Larry.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Hotrodboba400
12-10-2019 07:07 PM
db057
04-28-2019 07:45 AM
scottmoyer
09-07-2015 07:06 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: anyone ever port and polish a carb?
