edelbrock electric fuel pump pressure drop
Old 05-18-2006, 05:55 PM
dmason's Avatar
Car: 89 Firebird
Engine: 383 stroker 11 to 1
Transmission: th350
Axle/Gears: 3.73 posi
Just installed an Edelbrock 120gph electric pump in the engine bay. Feeds my Holley at 6.5 psi, sometimes. I pulled the old pump out of the tank and added some fuel line with a 90 fittting at the bottom as a pickup. I am using the old "high pressure" line as the supply to the pump. When the engine is cold I've got perfect 6.5 psi, when it runs for a while the pressure drops to almost nothing. The motor runs fine, though. It is not starved. Am I stupid or what here? It appears that once the carb's bowl is filled then the pressure drops, but I always have enough fuel to feed the carb. This pump does not have a return and is designed to not need one. Any ideas?
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
jklein337
09-19-2018 06:23 PM
92camaroJoe
08-13-2015 06:07 AM
Kaweh
08-09-2015 02:54 PM
Quick Reply: edelbrock electric fuel pump pressure drop
