installing a BG280 pump
1 Post
Car: 1987 IROC
Engine: Destroked 377
Transmission: TH-400
Axle/Gears: 9inch with 3.70's
I dont know where i should of put this thread. I thought it might go here. i am about to install a BG280 pump with the BG5000 filter. i have my stock gas tank sumped. is anyone running this setup and do you have any pics on where to mount it? Also i think im going to go 10an to the pump then 8an all the way to the motor. Right now i run a holley 130gph mechanical pump. the car went 11.5 i want to add nitrous so thats why im doing the new fuel system. any help? thanks.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you can forego the part about using that system specifically, you might get some advice about mounting, etc.
evilstuie
01-09-2020 08:29 PM
toronto formula
11-10-2015 06:17 AM
