carb bogs after throttle
Old 02-11-2007, 06:03 PM
wolf4pawsdown's Avatar
Car: 1986 trans am
Engine: soon to be chevy 350
Transmission: auto
Axle/Gears: stock
i have a 1986 transam with the quadrajet, i just resntly put on a open filiment k&n filter on it and now when i put more then half throttle it bogs down pretty bad. i just got the car last week and never owned a quadrajet before so i have no clue where to start. does anyone know what could be the problem?
Old 02-12-2007, 10:48 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
First things first, remove your air cleaner, and touch the seconary air valves with your finger, do they fall open and stay open, or do they spring back with some force?
May need to adjust secondary tension.
Think the open element is blocking the movement of the secondaries perhaps?
Old 02-13-2007, 11:34 AM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
I've allready ajusted the AV according to the tech article and it got rid of some of the bog, and no the open air filiment isnt blocking them. I also just put in a new fuel filter and ran some carb cleaner throught it, but it still bogs down. I dont want to tighten the AV spring any more because im getting close to that one turn limit the tech article as talking about.
Old 02-13-2007, 12:50 PM
Sonix's Avatar
Car: 1982 Trans-Am
What rods and hanger are in there? If you've got any other upgrades on the car, it might be leaning out on the secondaries by now. Maybe try an earlier(alphabetically) hanger, or thinner rods.
Old 02-14-2007, 01:55 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
its got the stock rods and hanger in there, and the only other thing done is a flowmaster catback. ill run down and pick up some new rods and hangers i guess.
Old 02-14-2007, 03:27 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The air cleaner lid may be interferring with some sort of mechanism, such as choke or AV.
Old 02-14-2007, 09:11 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
no theres no clearence issuse's with the air filter and any way i made sure. im ordering some stuff from jegs soo ill pick up a rod and hanger set too. hopefully thats it cuz i cant dish out for a new carb yet.
Old 02-14-2007, 11:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Post up the part # when you do, I don't think i've seen a kit for that before.
Old 02-14-2007, 11:22 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
the part number for the one im looking at is 350-1992 from jegs, im not sure thats what i need so im hesitant on ordering it.
oh and i have another Q, is the pontiac 305 the same as the chevy 305? cuz im looking at some intakes and stuff for a chevy small block and if its the same as the pontiac v8
Old 02-14-2007, 11:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
no pontiac 305 existed. You have a chevy 305.
That kit is for a non-cc q-jet. The secondary rods and hangers will work, but the rest you can't use (unless you've swapped to a non-cc setup...)
Just buy the kit of hangers, and secondary rods.
Something like
350-1960
and maybe 350-1951
Edelbrock only makes a few sets of secondary rods, 350-1950 to 350-1954
I don't know how they compare to the common junkyard ones I usually snag (DR etc). Check on the main page of TGO for a comparison of Q-jet secondary rods.
I'd want to know what you have on the car first, before ordering these anyway. If it's got the stock L69 parts, it's probably F / DR - which should be fine.
oh, did it get better when changing the air valve tension? That's a good sign that you just need to tweak the secondary rods/hanger. If not, then it's something else, like fuel supply, etc.
Old 02-15-2007, 11:08 AM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
yeah it got better when i adjusted the AV , and its all stock l69 parts that im aware off. the guy that i bought if from said he rebuilt the motor, its only got 90,000 miles on the whole car. thanks, ill check out those PN and the pages and hopefull yget this stuff sorted out soon.
Old 02-15-2007, 01:09 PM
five7kid's Avatar
Engine: LS1/LQ4
'86 L69? If so, you have one of 74 cars ever made (and I believe they were all Camaros, but not sure about that).
What's the 8th character of your VIN? Or, is this an LG4 to L69 "conversion"?
It's highly suspecious that this all came up when you put on a K&N air cleaner. Why did you do that? The L69 air cleaner is superior to any open element (and I have absolutely no love lost for K&N).
Me thinks you have an LG4.
Old 02-15-2007, 09:14 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
well the 8th digit is h um i put on the k&n filter cuz the old one was missing some pieces.
it says that only 26 transams where made with the l69 h.o. engine but they stoped making then due to a fuel boiling problem
Old 02-15-2007, 10:18 PM
five7kid's Avatar
Engine: LS1/LQ4
"H" = LG4.
Old 02-15-2007, 11:00 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
hmm ok well i still have the problem lol
Old 02-15-2007, 11:55 PM
five7kid's Avatar
Engine: LS1/LQ4
And the problem appeared when you switched air cleaners?
Old 02-18-2007, 12:47 PM
Car: 1986 trans am
Transmission: auto
Axle/Gears: stock
well i didnt notice it till i put the new air cleaner on it because i could hear it bog down and when i put the stock one back on i could notice it just by driving around . i ordered new rods for it ill let you guys know if that helps when they come in
Old 02-19-2007, 03:56 PM
z28boy88's Avatar
Car: 1983 Camaro Z28
Engine: 305 V8
my 1983 camaro had a similar problem, id push the gas down, it bog down and want to die, it also a a Q-jet on it, i switch with a different Q-jet, and it runs fine now
theshackle
09-17-2020 08:26 AM
Infested
05-22-2018 11:56 PM
777Shock777
10-29-2015 04:30 PM
someone972
08-30-2015 12:52 AM
GouldyGTR
08-21-2015 10:43 PM
Quick Reply: carb bogs after throttle
