Need a bracket
Old 04-05-2007, 06:17 AM
Camarothatcould's Avatar
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Need a bracket
I need to know what bracket to purchase for this carb. I need the one for the automatic trans, seeing it as I have a 700R4. thanks
Holley 750 DP
Old 04-05-2007, 08:26 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Need a bracket
Is that carb on backwards or is It just me ?? But anyways I have a mighty demon 650 and the breacket I have works perfect with it and it's for use with an automatic.
http://www.csr-performance.com/Merch...gory_Code=CT41
Old 04-05-2007, 09:16 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Axle/Gears: 273 pegleg
Re: Need a bracket
Would you happen to have a picture of your Demon with that bracket installed? From the pic in the ad, it's impossible to tell how it's supposed to work.
Dave B
Old 04-05-2007, 09:29 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Need a bracket
I dont have a pic of mine but this is the closet thing I could find for you.
http://www.jegs.com/webapp/wcs/store...0002_752613_-1
Old 04-05-2007, 09:58 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Need a bracket
Pssst...carb's on backwards
I know it's not bolted down but it made me scratch my head at first lol
Old 04-05-2007, 10:33 AM
D BERRY's Avatar
Car: 89 Camaro RS
Engine: LO3
Re: Need a bracket
Appreciate the pic, but I still don't see how it helps you hook up the TV cable from the 700r4. Is the bottom hole in the throttle lever made for the TV cable to attach? And what does the cable housing attach to, is there a provision, not shown in the pic, for the TV cable?
Dave B
Old 04-05-2007, 10:43 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Need a bracket
The top bracket on the csr-631 is for the throttle cable and the bottom bracket is for the tv cable. they way your talking its sounds like your asking about the carb itself not the billet bracket I am takking about. And the pic is not of the CSR-631 its the closest thing I could find that looks like it and is mounted on a carb. I have the bracket because I have a 1 inch carb spacer so I had to fix the cable geometery.
Old 04-05-2007, 02:23 PM
Car: IROC/F250 7.3
Engine: LS12367
Transmission: Autos
Re: Need a bracket
I just set the carb on for pics. geeze...
but thanks guys
Old 04-05-2007, 03:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Need a bracket
www.summitracing.com
search for holley 700R4 bracket
then you're done.
Old 04-05-2007, 03:30 PM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: Need a bracket
There are 2 brackets you will need. One made by Holley that attaches to the carb lever. It adds the attachment stud and locates the geometry. It also needs the side bracket that will hold it in place along with the accelerator cable. It attaches to the LR carb bolt/stud amd has an alignment tang. Also check out BowtieOverdrives.Com. They have a nice kit that notonly is carb specific (Holley,Edel,Q-Jet,Demon) they also correct the geometry and have the appropriate TV spring for the valve body. Believe me, without the full kit, you are looking at some PITA TV adjusting and possible future damage. Jegs also has a bracket kit of billet alum.
Old 04-06-2007, 07:56 AM
Tech @ BG's Avatar
Re: Need a bracket
Get the kit from Bowtie Overdrives www.700r4.com it will make your life, and the life of your transmission much easier!
armybyrd
Carburetors
10-20-2015 03:57 AM
jovibuilt
Exterior Parts Wanted
10-18-2015 08:12 PM
meeklay812
10-01-2015 03:46 PM
dbrochard
Interior Parts Wanted
09-28-2015 07:40 PM
armybyrd
09-26-2015 03:37 PM
Quick Reply: Need a bracket
