Fuel Line and Pump Questions
Old 04-05-2007, 11:00 PM
trumps2000's Avatar
Car: 1985 Z28
Transmission: T-5 5 Spd
Axle/Gears: Built 10bolt w/3.73s
I'm about to bolt-on some more power to my motor via blower and cam and have a couple of questions about keeping it fed. I'm looking at about 400HP. I'm planning on using stock lines for supply return.
Will the stock line ID (5/16"?) supply enough fuel while using a mechanical fuel pump?
I'm thinking if not, I could go electric. The higher pressure output of the pump should overcome the smaller ID. I was thinking of using a Holley Blue pump. Anyone use this pump, before? How noisy is it?
Old 04-05-2007, 11:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel Line and Pump Questions
You'll be fine with stock lines and a mechanical pump.
Old 04-05-2007, 11:07 PM
trumps2000's Avatar
Car: 1985 Z28
Good to hear. Any recommendations on mech. pump? The higher flow pumps seem to need an external regulator.
Old 04-05-2007, 11:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The Carter M6900 puts out a carb friendly 6 PSI and 120 GPH free flow. It has no return, though.
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
Andrew6.688
12-13-2015 10:59 AM
NBrehm
08-25-2015 11:49 PM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: Fuel Line and Pump Questions
