Choke thermostat. - Third Generation F-Body Message Boards
Choke thermostat.
Thread Tools Search this Thread
Old 04-19-2007, 07:58 AM   #1
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
Choke thermostat.
Hi All,If i have the choke thermostat out,ie, the type with the metal coil,if i apply
power to the connector where the choke power wire goes to normally,should it heat up or should the coil move at all,as i tried this and nothing happened.I checked at the coil itself with a multimeter and got 12 volts so i dont know if its working or not.I'm just trying to work out my current problem and eliminate things as i go.Thanks for any help.
Alicat.
alicat is offline vBGarage Page   Reply With Quote
Old 04-19-2007, 11:10 AM   #2
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: Choke thermostat.
The coil is bimetallic. When it has power applied to it, the 2 metals heat up at different rates and it causes the thing to spin slightly in turn opening/closing the choke plate.
If you have a full 12v on the wire going to the choke, chances are the choke has bit the dust. Especially if it doesnt feel warm(or hot) to the touch after a drive.
84z28350 is offline vBGarage Page   Reply With Quote
Old 04-19-2007, 01:05 PM   #3
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If you take the thermostat off of the carb, and apply 12 volts to the terminal, you have an open circuit.
It needs a complete circuit, so you have to ground the coil as well.
If you did that and it didn't move, then you've got a defective thermostat.
Assuming this is a stock carb, that is, which only has one wire and is grounded through the carb. Aftermarket carbs/choke thermostats often are 2-wire.
five7kid is offline vBGarage Page   Reply With Quote
Old 04-19-2007, 08:31 PM   #4
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
Does the choke thermostate get a signal from the engine temperature sensor, or will the bimetal coil heat and open the choke regardless of engine temp?
How do the engine / computer communicate with the carb choke?
What happens if one heats up before the other? Like defective choke coil, or too cool a thermostat or defective engine temp sensor and both the carb and engine are not in sync with regards to temperature.
These questions are in reference to the feedback carb system.
Thanks!
johnsonm is offline vBGarage Page   Reply With Quote
Old 04-20-2007, 12:43 AM   #5
five7kid's Avatar
Engine: LS1/LQ4
The computer has nothing to do with it. It's in the alternator - when there's enough voltage from the alternator, it kicks a relay that powers the choke thermostat.
Old 04-21-2007, 06:27 AM   #6
Axle/Gears: Stock.
Hi,I forgot to ground it,so i did that and the coil moved around about 1/4 inch and got warm as well so it works ok i assume.Now i'll have to keep checking things out until i find out what's wrong with the thing.It's defininitely something to do with the carby as far as i can see,i just have to work out what.
Alicat
Old 04-21-2007, 08:34 AM   #7
Aside from the "does it heat up?" test you also want to test it's resistance. You must do this when it's cold (room temperature)- not heated up. You should see 5-10 Ohms resistance on a good one. 20 Ohms max. If it's beyond 20-25 ohms it's getting "weak" and won't work reliably.
Damon is offline vBGarage Page   Reply With Quote
Old 04-22-2007, 06:14 AM   #8
Axle/Gears: Stock.
Okay,i tested the resistance and got between 13 and 14 ohms so it's probably
not bad for a original one.
Alicat.
Thread Thread Starter Forum Replies Last Post
Carb rebuilt, still no start, stumped. No fuel? GeneralIesrussi Carburetors 3 10-30-2015 03:36 PM
1984 L69. Overall Poor Warmup and Poor Driveability Saxondale Carburetors 33 10-01-2015 11:26 AM
Victor jr. Water plugs/ sensors 3rd gen money Carburetors 2 09-30-2015 07:42 PM
Qjet dies from a high idle ndndndnd Carburetors 2 09-16-2015 05:13 PM
Problems with -86 305 TPI firebird, stalls when pressing gas, code 34. MikkoV TPI 2 09-09-2015 05:25 PM
Go Back   Third Generation F-Body Message Boards >
Tags
56, alternator, carburetor, choke, cools, do, e2se, ohm, ohms, resistance, rochester, test, thermostat, thermostate, thermostats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright © 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
