Recommendations for fuel pressure regulator
Car: 1988 Mazda RX7
Engine: 350 L98
Axle/Gears: 4.11
Alright
Here is the scenario:
350 with Q-Jet carb and OE intake
I have converted from a FI setup and would like to continue using my electic fuel pump, but will need to "throttle" the pressure down from 20+ psi to 6 or 7 psi.
Has anyone continued using the original fuel pump from a TBI/TPI setup when they went to a carb? If so, what regulator did use and where did you buy it?
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Recommendations for fuel pressure regulator
mallory #4309 from summitracing.com
9192camaro
16
02-03-2019 12:21 AM
