Installed an Edelbrock, now I've got issues...
Old 10-08-2008, 08:22 PM
bunkie21's Avatar
Ok heres the deal. I have an LG4 with full exhaust, performer intake and a standard HEI. I installed an Edelbrock 1406 600cfm carb in place of a poorly operating non-cc quadrajet that had no choke.
The problem is that from idle - 2000k rpm seems like a total dog and seems to have some sort of hesitation or maybe even a bog. Its hard to describe but feels something like the ignition is not working properly but after 2K that car runs and runs good. Since I have 2.73's I spend most of my time below 2K so its starting to get on my nerves.
Does anyone have any clues as to where I should look? I have no experience with Edelbrock carbs so I'm at a loss. Also I have played around with the timing alot so I dont think thats the problem.
Old 10-08-2008, 08:45 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
Re: Installed an Edelbrock, now I've got issues...
did you replace the dizzy with a vac advance one or leave the stocker on, wait never mind you had a non cc qudra
it needs adjusting, but without being there i cant really tell you what way to go
Old 10-08-2008, 09:23 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
What did you do for the choke on the Edelbrock? Also, which vaccum are you tapping into for the advance on the distributor, the manifold vaccuum port or the venturi port?
Old 10-09-2008, 07:35 AM
bunkie21's Avatar
The HEI is fairly new and is a Jegs brand, nice unit for the price.
As for the choke I spliced the original choke wire that was used for the original CC quadrajet. And I currently have the vacume advance on the ported vacume. I tried it on the other and didn’t notice much of a difference.
89RS_82Z, are you saying that you think the carb needs adjusting? Someone suggested that I put a lighter spring on something in the carb, I would have to look at the email to tell you exactly what they recommended.
* Edit - I have also noticed that when I first start it in the morning it jumps up to 2000 rpm, I tap the throttle and it goes down to 1100 or so and stays there until I put it in gear or it warms up.
Old 10-09-2008, 08:48 AM
Street Lethal's Avatar
Are you running off of the primaries, or the secondaries though? Meaning, are you babying it to 2000-RPM, or are you at wide open throttle from the get-go? Assuming your at WOT, it sounds like you need to adjust your secondaries. If it's bogging, they're opening too soon. If the engine feels like it's holding back, they're opening too late....
Old 10-09-2008, 10:22 AM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
if you're not a wot, then you need to adjust the idle mixture, because when you're at a cruise/light throttle application, then thats what you're running off of. I think its been covered on here, if you can't find it, i know car craft showed how to do it in last months issue, so you should be able to find it on they're website.
Old 10-09-2008, 12:16 PM
bunkie21's Avatar
It’s specifically at light throttle. So the idle mixture (the two "screws") affect light throttle and could be causing the stumble. I will check and see if I can find the info on the board but does anyone know what a safe starting point is? I don’t know where they are at now but will check it.
Old 10-09-2008, 01:05 PM
Lean out both mixture screws (clockwise), but don't bottom them out too hard. When both are closed, richen them (counter clockwise) 1 1/2 turns out each. It's best to set them with a vacuum gauge hooked to a manifold vacuum source....
Old 10-09-2008, 01:44 PM
bunkie21's Avatar
And I set them for the highest vacuum, right? Do they need to be set the same or just max vacuum?
Old 10-09-2008, 03:17 PM
You'll want to meter them as close as possible, so fatten one mixture screw until the vacuum gauge increases in inches to it's highest point, and no further (count the turns), then immediately bring the other mixture screw to the same exact point. Lower the fast idle screw back down to a reasonable RPM, then repeat the process all over again until the gauge can go no higher. You'll want to do this in gear, so make sure the e-brake is up....
Old 10-09-2008, 03:46 PM
bunkie21's Avatar
Great! I will let you know how it goes. Thanks for everyones help.
Old 10-10-2008, 12:08 PM
kennn's Avatar
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
I assume this applies to LG4 auto only, not manual.
Old 10-10-2008, 01:18 PM
blue85305's Avatar
Car: 1984 camaro
Axle/Gears: 3:42
correct assumption
Old 10-10-2008, 05:31 PM
bunkie21's Avatar
Ok, I followed the above advice and I think that it fixed my problem. I havent driven too many miles yet but I think its fixed. Thanks for the info and help!
Old 10-10-2008, 07:57 PM
Of course it does, just leave it in neutral with a manual....
theshackle
09-17-2020 08:26 AM
fasteddi
09-02-2015 10:29 AM
BlackphantomZ28
08-22-2015 01:00 PM
86IROC112
08-17-2015 02:00 PM
89-S-dime
08-12-2015 11:57 AM
Quick Reply: Installed an Edelbrock, now I've got issues...
