3 duece setup
Car: 91 Z28, 91 RS
Engine: 383, 350
Transmission: 700R Crappy, WC T-5
3 duece setup
I need some help guys. I am thinking about trying a three-duece setup on a thirdgen. I was wondering if anyone has attempted this on a thirdgen yet. I like the idea of the SS hood with this stuffed under it? Any Input?
http://store.summitracing.com/partde...3&autoview=sku
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard thirdgen.org.
I don't recall seeing anyone on the Board with that type of set-up. The sad part is you spend $2k and get out-run by a guy with a $700 single 4-bbl and aftermarket intake set-up.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 3 duece setup
Life's too short to spend all that time balancing multiple carbs for no benefit.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: 3 duece setup
it sure would look cool, don't know if it would fit under and ss hood or not, might need something a bit larger.. it sure is pricey but if you're building a show car I'd say go for it.. if you're just building something to go fast there are cheaper ways that would work better tho...
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: 3 duece setup
like stated above, unless it is a show car, dont bother
LT1Formula
10-08-2015 08:34 PM
