explain how this canister control valve works
Old 01-28-2009, 11:09 PM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
I would like to know how #9 works. I can understand the idea of 3 ports- an in port, an out port, and a vacuum port to open and close it. Why does this one have 4. I can't quite figure out the flow of fuel vapor. I know it enters the large bottom port and I thought it could only exit through the the big port just above it. Yet diagram looks like fuel vapor could go up to top of valve. I'm confused, and would like to understand this valve and how it interacts with the carb. thanks. This is on a 84 z28 305. I just noticed that this diagram is missing the tank pressure control valve that should be on line #8
Old 01-28-2009, 11:35 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It collects vapors from both the fuel bowl and the gas tank when the engine isn't running.
The pressure valve isn't in Line #8. It has its own port off the tank pick-up.
Old 01-28-2009, 11:43 PM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
Re: explain how this canister control valve works
I think this is starting to make sense now. All fuel vapors are drawn back into the carb or actually the throttle body by port #3. Both bottom ports, 4 & 10 are actually in ports. Correct??
Old 01-28-2009, 11:53 PM
five7kid's Avatar
Engine: LS1/LQ4
Wait, I see what you mean by the control valve. Never mind what I said.
https://www.thirdgen.org/forums/atta...se-routing.jpg
The tank and fuel bowl are open to the canister when the engine isn't running. When running, the vapors are pulled out of the charcoal bed into the engine by the flow of fresh air from the bottom of the canister.
Ghettobird52
12-29-2023 08:23 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
lakeffect2
08-23-2015 08:44 AM
THABADGUY
Brakes
08-11-2015 03:43 AM
Quick Reply: explain how this canister control valve works
