Quadrajet vacuum lines? - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 07-31-2009, 07:57 AM   #1
Car: 87 T/A * 86 T/A
Engine: 305 TPI * 305 4bbl.
Transmission: Manual * Auto
So I bought an 85 T/A that has had a 355 dropped into it. Right now, its tsrats fine, but when you throttle up, it bogs badly, and after a few minutes of running, dies. It seems to be sucking air under load, making a whuffing noise. Very little power.
Now, there is a vacuum tree that is completely capped off behind the carb, and the vacuum canister isnt hooked up at all. I'm hoping this is a combination vacuum and timing issue. I pulled the only info off the carb I could find. On the drivers side of it, it says Quadrajet by Carter, and has the nubers 17058213, 1508 BJB.
How do I determine what this carb is, and what the proper routing for the vacuum lines are?
Akodo is offline vBGarage Page   Reply With Quote
Old 07-31-2009, 08:31 AM   #2
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
What an amazing thing, this Goggle. . .
These guys used that very carb # for their example on how to decode q-jet numbers http://www.4wheelnoffroad.com/qjetid.html
That would be a non-computer q-jet. Unless you have a non-computer distributor, it will never run correctly.
Sounds like your poor car has been hacked up by a ham-fisted magazine mechanic. Post pics if you can, we might be able to help you sort it out. Carb, distributor, any vacuum lines that are attached, those that are capped off, etc.
five7kid is offline vBGarage Page   Reply With Quote
Old 07-31-2009, 10:08 AM   #3
Re: Quadrajet vacuum lines?
Actually, I was kind of surprised by how cautiously they did the mod. No wiring was cut, even the injector harness is neatly coiled up and tied to the fire wall. It just looks like it was never finished. Looks like some of the fuel lines were a little hacked however. Here are some pics, I'll try to get some better ones tonight.
Old 07-31-2009, 12:11 PM   #4
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ya don't need all that canister stuff as long as the right lines are plugged so you don't have a vacuum leak. Just don't plug the tank vent line.
this pic may help on hook up.
Gumby is offline vBGarage Page   Reply With Quote
Old 04-29-2010, 10:29 AM   #5
Gumby,
I was just wondering where you got that image from was it from a book you acquired, i believe what ever you have could really help me
jcon104 is offline vBGarage Page   Reply With Quote
Old 05-15-2010, 08:43 PM   #6
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Quote:
Originally Posted by jcon104 View Post
Gumby,
that was from the direction for one of those holley eco crap carbs that was to replace a stock Qjet.
Thread Thread Starter Forum Replies Last Post
89 gta 5.7, runs too rich, won't rev, stalls instead gta892000 TPI 11 10-04-2015 12:52 AM
Part identification camarohelp Tech / General Engine 5 09-12-2015 06:45 PM
[NV] Turbosmart eBoost Street Boost Controller Doobie52 Engine/Drivetrain/Suspension Parts for Sale 0 09-11-2015 07:19 PM
88 5.7 tpi bouncing idle and stalling IROCtometal TPI 3 09-09-2015 11:01 AM
Vacum lines snakeshooter V6 3 09-07-2015 12:13 PM
Go Back   Third Generation F-Body Message Boards >
Tags
17058213, car, carbs, faq, hook, hoses, installation, leak, lines, pics, quadrajet, rochester, routing, taking, vacuum, vacuumscom
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators.
