need help i cant identify this holley carb
Old 11-03-2009, 02:03 PM
louflemm's Avatar
on the carb it says 83310-1 2125 right under that one side says R81 other says P80. On the base of the carb there are these numbers 12R-4770B. its a 4 barrel. if anyone know what carb this is please let me know. thanks
Old 11-03-2009, 10:01 PM
mrjhett's Avatar
Car: 89 Formula
Engine: 5.7
Transmission: 5 Speed Man.
Axle/Gears: Spohn 3.73 with Strange Axels
Re: need help i cant identify this holley carb
From what I can find out on the web...it's either a 750 or 780. I am not sure if it's set up as a double pump or dual feed. If it has the jet/fuel plate on the back side it would be a double pump, if not then dual feed.
Either one is a great carb. I used to have a 780 dual feed on my small block 350 that flowed 810 CFM, with only some minor mods.
Look up just the 83310-1 number, and you should be able to find out more info.
Good luck.
Old 11-04-2009, 10:18 AM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
www.mortec.com
Has a good listing of Holley carbs and part numbers
Old 11-04-2009, 01:08 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Originally Posted by bestracing
www.mortec.com
Not very good, actually, as it is sparse with information, and in this case, the information it has is wrong.
Holley's website has a better reference: http://www.holley.com/data/TechServi...%20Listing.pdf
Looks like a 4160 model vacuum secondary 750.
By the way, mrjhett, "dual feed" and "double pumper" are unrelated aspects of Holley carbs. It's either "dual or single feed", and either "double pumper or vacuum secondary".
Old 11-07-2009, 10:53 PM
mrjhett's Avatar
Car: 89 Formula
Engine: 5.7
My bad.... I guess I didn't say what I meant.... Thanks for clarifing.... I know the diff between those...jus didn't say it right lol Let me try now:
The 780 (Vacuum secondary , without the jet plate...jus the float bowl on the backside) was the carb I had...
BTW Thanks for the links, I'm going to save them...even though I'm not currently using carbration anymore....
F.I. 57 Belair
08-23-2021 01:09 AM
Linson
09-21-2015 01:08 PM
WickedBowtie
Members Camaros
09-17-2015 09:13 AM
makaveli09
09-15-2015 10:43 AM
WickedBowtie
09-11-2015 11:24 PM
Quick Reply: need help i cant identify this holley carb
