Replacing E4ME with M4ME/D?
Old 05-14-2010, 10:39 AM
ROFLsplash's Avatar
Car: 1987 Trans Am
Engine: 5.0 L
What is the difference between an E4ME and an M4ME(D)?
While looking to rebuild my carburetor I stopped by a local rebuild shop and they told me that I could use this one. I took the number off the side of the carb and it was 17085227, which from what I can tell is an M4ME or M4MED? Is there a problem with replacing my computer controlled electric carb with this one?
Old 05-15-2010, 09:04 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Replacing E4ME with M4ME/D?
It's not as simple as bolting it on:
https://www.thirdgen.org/forums/carb...t-cc-carb.html
Old 05-15-2010, 09:19 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
as the article should state... you will need to change your distributor from an electronically controlled to a vacuum controlled unit, otherwise performance will suffer as well as everything else... you will need to install a standalone TCC lock up switch... you basically need to bypass everything that is electronically controlled by the ECM...
Old 05-17-2010, 11:34 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The first letter: "E" means it's electronic control, "M" means manual. The last letter means electric choke.
http://www.carburetion.com/Number/bynumber.asp "85-87 Chev/GMC/Truck BOP Grey Sol." "Grey solenoid" means it is the dual volume accelerator pump, which is a M4ME type. It won't have the TPS connector, and is not the proper carb to replace yours.
Out-Cast
12-31-2015 04:40 PM
Dan Hubbard
08-12-2015 09:05 PM
marcusaw
08-10-2015 08:13 AM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: Replacing E4ME with M4ME/D?
