flames and fuel spitting from carb 1406
Car: '85 Camaro z28... '90 300zxTT Z32
Engine: soon to be 350(carb)... VG30DETT
like it says I got flames and fuel spitting from my 1406 on a 305
things I've done recently:
1. put fluid in my steering pump
2. changed my ignition wires for brand new ones
3. adjust idle
it was starting when I first put the wires in and now it won't start it's spitting out fuel from the carb and flames occasionaly
please help!!
I have a 1405 carb lying around should I just replace the 1406? or is it the wires? they're brand new. I just printed out the firing order so I'm going to check that also. many things It could be but it was fine a few days ago?
need help-!
3. adjust idle
please help!!
need help-!
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: flames and fuel spitting from carb 1406
Check the "new" wires for shorts - test continuity with ohm meter - I've bought several "new" wires with shorts before.
Car: 1987 Z28 Camaro (T-tops)
Engine: Carb'd 305
Transmission: 700R4 (auto)
Axle/Gears: Posi / 3.27
Yeah, check your wires and make sure they are in the right order. Also check your cap and rotor, make sure your timing is still ok.
Car: 1984 Z28
Engine: 4 bolt 350 out of a 78 chevy pickup
Axle/Gears: posi, 3.73
Where is the fuel spitting from? metering rods may be gunked up and unable to properly shut of fuel/air mixture... And what happens when you mix fuel with ignition or extreme heat? if not that, check the level of your floats to make sure theyre ok...
theshackle
09-17-2020 08:26 AM
beachrodder
08-25-2015 08:05 AM
86IROC112
08-17-2015 02:00 PM
1406, 305, carb, carburetor, carburetorflames, carburetors, coming, flames, fuel, gas, spits, spitting, start, thread, wont
