CARB'D GUYS. WHAT THROTTLE BRACKET
Old 01-01-2011, 10:37 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
what throttle cable/ trans cable bracket are you guys using. i went from a TBI to a holley and a 700r4tia
Old 01-01-2011, 10:52 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: CARB'D GUYS. WHAT THROTTLE BRACKET
I used this one: http://www.summitracing.com/parts/EDL-8030/
It was very sturdy so that the TV cable didn't bend it - there's alot of pressure from the TV cable and you need a good strong bracket.
I did however have to make a small mod for my TV cable - I had to drill an extra hole in it in order to get my TV cable properly adjusted - but it's a great strong piece and drilling the hole took all of 3 minutes.
You need to make sure you also use a TV cable geometry corrector for your Holley - it corrects the geometry and keeps the TV cable pulling correctly - connects to the Holley linkage and TV cable connects to it. Look at: http://www.summitracing.com/parts/SUM-700202/
Old 01-01-2011, 10:58 AM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
what set of holes does the bracket bolt to? the last 2 on the intake?
Old 01-01-2011, 01:07 PM
91-RS's Avatar
Car: 91 RS
Engine: BUILT 327
Axle/Gears: 3:73
anyone got pics of this installed?? post em up!
Old 01-01-2011, 06:22 PM
Car: 1992 RS
Engine: Carbed 350
Caught me after dark - maybe I can get a pic tomorrow.
Yes - the last two intake bolts IIRC - I'll recheck tomorrow.
theshackle
09-17-2020 08:26 AM
evilstuie
01-09-2020 08:29 PM
pimp2303
07-27-2017 02:03 PM
Genopsyde
11-11-2015 10:46 PM
Dialed_In
08-20-2015 01:45 PM
Quick Reply: CARB'D GUYS. WHAT THROTTLE BRACKET
