carb fuel question
Old 03-21-2011, 09:24 PM
bcfipp's Avatar
carb fuel question
I swapped from tpi to carb setup. I have a 305 motor. I changed the tpi pump to a tbi pump. I am running a mallory fuel pressure regulator. My question is why do I have to use a pressure regulator (cheap one from advance) on my return line. If I take the return line regulator off. My fuel pressure gauge maxis out at the highest reading. Anyway to fix that? Thanks for the help
Old 03-21-2011, 09:30 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: carb fuel question
You don't - whoever told you that was wrong!
All you need is the Mallory regulator, nothing else. Your pressure is maxed out because the el cheapo pressure regulator is restricting the return line - remove it!
Feed line goes into side of Mallory, return line goes in the bottom of Mallory, line to carb goes in other side of Mallory - done. Feed loine is the 3/8 line, return is the 5/16 line. If using hose barbs, make sure you don't try to shove a 3/8 barb into the 5/16 hose - it'll cut the rubber inside the hoise and cause yet another restriction.
Frozer!!!
01-19-2024 04:55 PM
MustangBeater20
10-29-2022 09:20 PM
midge54
12-27-2019 04:14 PM
Infested
05-22-2018 11:56 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: carb fuel question
