Switching my TPI to Carburated, any tips?
Car: 1987 Trans Am
Transmission: 700R
So, me and my step dad are finally getting fed up with this TPI crap, and we're just gonna carburate the motor.
It's a 350 Chevy, any tips on what kind of intake we should get?
Or any other kinds of tips would be appreciated, thanks!
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: Switching my TPI to Carburated, any tips?
Is it a stock 350 TPI? Any reason you want to switch to carbed? If it's not running right currently, just slapping on a carb may not fix it. Just curious.
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
if you do decide to get rid of the TPI stuff, I have a buddy wanting to run TPI on his 1980 Z28 who would be very interested in the intake
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You'll need to wire the fuel pump to run if you plan on keeping the electric in tank pump.
You'll also need a return style regulator to keep pressures down. I used a Mallory 4309 return regulator. Carbs don't like 40+ PSI.
You will lose converter lockup unless you install a kit or make your own. Without converter lockup the transmission will generate more heat and lockup just makes the car more friendly for highway speeds (4th gear).
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
you also need to sell me the TPI setup including wiring harness and computer . youll need to remove the passenger side wire harness (since its all for the tpi) but keep the one on the driver side. theres gonna be a few wires that cross over behind the engine, but you can just fish those out and seperate them. o and the biggest thing is none of this is federally legal at all.
1 Post
Car: 86 IROC
Engine: 355
Transmission: WC 5spd
Axle/Gears: 3.24
DO IT!!! I had all sorts of issues with TPI; just finished the swap and realized why....26 year old wiring is no longer reliable. That, and the hack and slash job of previous owner(s) didn't help matters at all.
Here's my Jegs laundry list:
1 1 350-2101 INTAKE PERFORMER SBC 129.99 129.99
1 1 555-210002 Int Gasket-SBC-No HC 14.99 14.99
1 1 555-28030 BLUE RTV SILCONE 3-OUNCE 4.99 4.99
1 1 555-83200 INTAKE BOLTS SBC/MPR/AMC 8.99 8.99
1 1 555-15840 CARB STUD KIT 1.5" LONG 5.99 5.99
1 1 720-56 CARB GASKET Q-JET 4-HOLE 2.99 2.99
1 1 650-4309 RET REG 3-PORT GAS 3-12 89.99 89.99
1 1 510-0-80457S CARB 600 CFM E/CHOKE ZNC 269.99 269.99
1 1 555-40002 HEI DIST & COIL, SB&BBCHV 89.99 89.99
1 1 555-40200 IGN WIRES CHEV UNIV/MULTI 34.99 34.99
Notes from swap:
1) I have swirl port 187 heads that were slightly reworked.....the intake center bolt holes had to be hogged out. It was a PITA. Get the intake to match your heads.
2) They sent me the wrong gasket for the carb.
3) Distributor needed to be recurved even with my mild set up (comp 260h, no lope whatsoever)
I finished it literally a month ago....really not that bad if you sit for a night and understand the wiring diagrams in the Chilton's guide. Shoot me an email if you need some pointers.
Faz
Notes from swap:
Faz
Mikah1988 (12-26-2023)
Car: SOLD!!!!!
im not sure why you are doing this. a 350 tpi motor will run circles around a arbed 350 of the same. the only thing a carb does is maybe in some instances make more power up top and that is it. the driveability of fuel injection will be gone.
Car: 1986 Trans am
Engine: 5.3 LM7
Well....I love fuel injection myself and like TPI for a driver. A carb will run circles around TPI for power though with the right set up. However TPI is great for a street car and if the OP is leaving the motor pretty much stock, I would never swap to carbed.
Car: SOLD!!!!!
the key words are right set up. it will have to be tuned near perfect. then they need to know that tuning will continue when how and again when cold. i have had both carbed and fuel injected engines. to me the injected engines will always win out. if you took the money that you would spend to carb it then it could be repaired properly. as for a daily driver i have never seen a carb outdo a fuel injected engine.
now if you are a die hard gear head and dont mind the carb burps and tendencies then i say go for it.
1 Post
Car: 86 IROC
Engine: 355
Axle/Gears: 3.24
Oh yeah, forgot the other PITA....connections to the 3 port....had to scour a bunch of plumbing places to get the right bits. I think they sell them right from Mallory....highly worth the investment.
In terms of drivability, there are some drawbacks...can't just hop in a drive away like my Volvo or Civic, has to be warmed up or it will stall. I have flooded it trying to get it to restart after stalling it out as well......really difficult to flood with FI. That being said, there are so many variables with FI that I gave up. Again, I now know it was the wiring.
For me, it's a weekend driver....does not have to be reliable or fuel efficient. It's simple to work on, easily upgradable, and cheap to maintain....TPI is none of these.
In hindsite, I would do it again...for $800 in parts and a few nights work, she's running again.
Engine: 383 SBC
Like anything if it's tuned properly it shouldn't be a problem. A properly tuned carb and FI setup should run about the same. It just comes down to what you want. I agree fixing the TPI would be cheaper by the time you get intake, carb, linkage, regulator, lockup kit, etc.
Usually people just compare the cars in there area and use that as examples. One guy in my class thought it would be a good idea to put a tunnel ram and 2 650 DPs on a 305 Camaro, it washed the rings and filled the pan with gas. That shouldn't mean tunnel rams or DP carbs are useless. Another guy had a 305 TPI Camaro in high school it ran like crap. He put a lumpy Comp Cams camshaft in it that wasn't ecm compatiable, but that shouldn't mean all camshafts are junk compared to stock peanut camshaft.
To get an excellent tune you basically need a wideband and that's one of the downfalls. Your o2 sensor does that work for you currently. After the swap you're going to have to make the float, idle screw, mixture screw, and jet adjustments.
Some dyno shops will setup a carb for you on there dyno and wideband. You can get close with a vacuum gauge but it will not be dialed in 100%. I my idle screws within 1/8 turn or so correct off the vacuum gauge, but on the wideband they found a huge flat spot coming in around 3000 RPMs and up and that's when we found the demon carb was leaking vacuum.
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
coming from a carb to TPI swap. My tip, don't do it.
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
im the middle of a carb swap and im pissed that the fuel pump runs thru the ecm which is no longer, so what is the best way to get power to the fuel pump with out buying anything!! i need a starting point like maybe wiring in a 12v toggle switch strait to the relay somehow? and where the best place is to tap into ?
Car: 1986 Trans am
Engine: 5.3 LM7
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Blah Blah Blah same crap different person. I dealt with the "Nah Sayers" when I posted up a similar post a year ago before I did my TPI to carb swap. I had a lot of trouble with my TPI setup up and there are pros and cons to doing the swap. Truth is each person goes a different way when doing this swap. Im a paint and body guy so this engine stuff is a bit over my head but by doing this swap I learned so much. Do your research, keep askin questions, dont forget that there are actual tech articles on the home page, and good luck.
Here is a couple things off the top of my head:
You will need a Fuel Pressure regulator with guage, IT MUST BE A RETURN STYLE, If its an auto then you will need a TC Lockup kit, as for intake I got an eldebrock performer RPM intake lookalike off of ebay saved some money and the polished aluminum looks great, you most likely wont need a carb over 650cfm. I went ahead and had a motor built for my car so somethings were different with mine. I found out that using a TBI throttle cable worked great, the TPI cable is way to long. The TV cable on my 700R4 gave me a lot of trouble, make sure that the geometry is correct on it or it will throw it off. While you are at it you might want to think about putting a fan controller in the car so the fans turn on at a lower temp, I wired mine up so when my key is turned its on.
As for everyone that has been posting on here, lets try to keep the chatter on whether he should do it or not and focus more on the OP question. He is lookin for expirienced gear heads like you all to help make this easier on him not tell him whether or not he should do it. Im not pointing any people out or trying to offend anyone, and Im sorry if you took it that way. I have had to deal with it and it just makes things more difficult when you can't get an answer because people are continusouly discouraging what youre doing.
GOOD LUCK WITH THE SWAP and dont forget to post up a build thread when you are done
Car: 1986 Trans am
Engine: 5.3 LM7
I had a TPI car. Fired up every time I turned the key, got 18 mpg with a bigger than stock cam, and had excellent street manners. If the OP has never had a carbed car, then we want him to know that it will NOT be as driver freindly as an FI car. As long as he knows that then he can do what he pleases. In all honesty, he hasn't posted in here since his original post so I doubt he's coming back.
And as far as your fan wiring, I wouldn't recommend to someone to wire a fan so that it's on non stop....especially someone like me that lives in new england. If you need your heat to function, good luck with the fans on all the time. Plus, carbed motors like to run around 180 or so degrees and keeping the fans on will hurt that. My brothers car barely gets to 150 degrees and his fan is on a switch. It only just starts to go up from 150 while idling for a while. Wire the fans properly with a temp activation switch and you will be much better off. The less things to worry about while driving, the better.
Originally Posted by one92rs
im not sure why you are doing this. a 350 tpi motor will run circles around a arbed 350 of the same. the only thing a carb does is maybe in some instances make more power up top and that is it. the driveability of fuel injection will be gone....
Car: 1987 Trans Am
Transmission: 700R
Holy crap, I didn't know I started this big of an argument.
I never really planned to get good gas mileage anyway, so thats no big deal.
I'm mainly just switching to carb, because my stepdad KNOWS he can get it running if we switch it.
I know alot of you guys have these cars as sunday drivers, or once a week cruisers or whatever,
but my mom bought two TA's for 3000 bucks, and we don't have any money to just blow on some Honda, so right now, this is all I have.
So in other words, I'm switching just for the sole fact of getting it running, so I can find a job and whatnot.
Car: 85 iroc-z28
Engine: 049 headed bbc 4?? C.I.D
Axle/Gears: 3:73 posi
I would say do it they're fine for a daily driver i'm19 and did the swap my self it was easy wouldn't change it for the world and if you decide to build a bigger motor then they are easy to adjust you can spend hundreds of dollars just getting a motor tuner by time you take it somewhere. But won't say they're better on gas tho. I did mine and love it but it's personal preference but I don't drive mine in the winter tho which wouldn't be friendly at all
Car: 85 iroc-z28
BTW I don't understand what people say by driveabilty personally I like carbs alot better fordriving especially mechanical secondary the the fuel and air is there when you w an t it. And no I don't needpeople saying i don't no anything about cars cuz of my statements cuz a carb is like anything else if you tune it then it will run good no troubles I have a Barry Grant750 double pumper wiith mechanical secondary and it starts up every time no troubles but I do no how to tune a carb really good tho. So its your preference do what you want it's your car and good luck with your car
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
your in for a host of problems ,all of which altho easy to deal with could be avoided by just repairing your car correctly
Car: 86 IROC
Engine: 5.0 TPI
almost every third gen camaro that is brought in, is seriously "boogered up" by people that obviously couldnt fix a can of soup, let alone a fuel injection set up. and it is sad really.because TPI is pretty much trouble free.it dosent require you to do anything EXCEPT leave it alone.AND as mentioned by another poster it is ILLEAGLE to modify our cars in this fashion
1 Post
Car: 87 Camaro
Blah blah blah, if you wanna do it, do it. Unless you live in a smog state. I had an edelbrock 1406 on my 355 and it ran great and got 27mpg highway. I have a CCC on my stock 305 now and I can't seem to get anywhere near that now. Personally if I had a TPI setup I would keep that and take it to a shop for their opinion then fix it myself but I always seem to fall into carbed cars...can't even get a TBI
Car: 91 Camaro RS
I had a TBI. not really worth trying to upgrade that system to run a healthy stroker. so I went carb and havent looked back.
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I did this swap and didnt look back. I bought used parts like a carb and intake. I used a TBI fuel pump since it was a low psi pump and I had one on the work bench. I got a billet fuel psi regulator from Jegs since it can handle up to 20 psi inlet psi. I probably should of bought a Mallory regulator and used the same TPI pump. The way I looked at it was, spend $$$ upgrading the TPI runners, base, and upper or save a lot and buy what I did. I gained no TQ although the power band increased almost 2k rpm's and increased 30hp.
Sorry I cannot help more but go for it just get a decent carb with mechanical secondaries and sell your tpi stuff to pay for it. If your dad knows and understands carbs I bet he can get it running right with decent mileage as long as you keep it off the second two barrels.
Car: 91 Camaro RS
with an auto, getting vac sec would be more eco freindly.
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
I'm very happy with my setup. 600 Summit VS carb, low-pressure pump, Digital-6 ignition, and Painless TC lockup kit.
Car ran a 13.9 last year and should run low 13's now. 310 cid, Vortec heads, LO3 cam, 1.6 RR's, stock stall. It's my daily driver. Just hit 254k on the odo.
Guest
Posts: n/a
Thanks any comments welcome, but please keep it constructive, I have given you the reasons, I am not looking for a debate, just good comments to get it done right.
Thank You
Guest
Posts: n/a
Thanks,
Wayne
The other issue is that any factory carbed engine you ever drove was a 70s dog of an engine. The TPI L98 was one of the first decently quick smallblocks chevy made since the 60s.
Car: 91 Camaro RS
a properly tuned carb with a light foot will get you decent gas milage. a properly tuned carb with a lead foot will get you performance. its possible to get both out of a carb, if you know how to tune one. 90% of people using a carb, bolt one on out of the box and go. itll work, but its not getting the best of either world.
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
my 2 cents are go for it. Then get in the back, pull your carpet up right over the sending unit and cut a hole. No grinding! This way you can get to the fuel tank. Then you take your fuel pump disconnect it and run a line of your own to the engine bay. Run one of those 60 $ carb elec pumps. Have a toggle switch. Then get you vacuum advance distrubutor. Vacuum can, Any will do. Manifold vacuum. Then have it tuned singing like a bird! Finely tuned carb and finely tuned timing will run an engine fine.
Not sure why people are ragging on going tpi to carb. I love my carb setup easy 300 hp and with vortec heads 400 is no prob. And if you know ehat your doing it can run great. After a very quick warm up in my driveway (I don't have a choke) I have no hesitation or throttle issues. Electrical problems are gone checklist includes 12V to the coil and nothing else I love it.
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
Cutting an access hole and hacking the fuel lines is a bad idea because you have to hook the fuel lines back up somehow. Do it right and drop the tank.
yea and youl have to drop the rear end just to do so! And not many have the time to do it. Youll have to have it on stands also which is very dangerous.
ok well what many do not know is my uncle did this on his 86 camaro, V6 swap, he put a monza spyder engine it with a 4 barrel and a TH350 behind it. Even welded his own drive shaft. he did everything himself, even built his own cherry picker himself. He's still alive. I got even more in expensive proposition and even more safer way to solve not having to drop the rear end, get you a 1/2 drill bit, drill a whole as center as you can on the part right behind the top of the back seat. Remember to pull the carpet back. When drilling have water fed, and dont go deeper then a 1/4 of an inch, and the eye ball it from there. Than you get the hack saw blade out. Dont even concider grinding. Just have patience and try to go around the lines. And if you like for s**ts and giggles just install a door there, primer and all that good stuff. Put carpet back down and then your done
Car: 3rd gen!
Engine: SBC
Transmission: yes
Axle/Gears: yes
That sounds like more labor than dropping the tank. And you didn't even mention what to do with the fuel lines.
#42
Car: 91 Camaro RS
here we go with the whole "dropping the rear" issue. I personally have removed my tank from my car more than once, and not any of those times did i drop the rear to do it. it takes me about half an hour to remove the tank from my car now.
#43
Car: 1986 Trans am
Engine: 5.3 LM7
I've dropped a thirdgen tank probably 5 times. It's really not that bad guys. Quit being lazy and get on your back and roll in some dirt! As long as you tilt the tank forward while pulling it with the axle at full droop it'll slide right out.
#44
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I was referring to the whole process, not just the part about cutting an access hole.
Rather than going through all this work to downgrade your car just because someone you know knows something about carbs, why don't you educate yourself on EFI and go from there? Did you consider the simple reality that switching your car to carb will make it illegal for street operation in all 50 states?
#45
Car: 91 Camaro RS
the only reason i went carbed is because i did a motor swap, and rather than try to get the stock tbi to run 400+ hp, i went with carb. Just swaping from TPI to carb on a stock engine isnt a good idea. if it were me, id get the tpi running correctly and not even think about carbing it
#46
1 Post
Car: 87 Camaro
Luckily for me I don't have a fuel pump in the tank, but unfortunately for me that means my car was carbed from the beginning. Honestly, I'd rather have TPI or even a TB just to have the upgrade from a carb. I'd rather have a TBI out of the two, though just because it's so simple.
#48
1 Post
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
read the sticky "welcome to carb forum" lots of good reading there, and wouldnt put your telephone number on the internet you are just asking for trouble there
#49
Just realized how old this thread is!
Last edited by DonW; 07-02-2015 at 08:22 PM. Reason: realized it was an old thread!
#50
For dang sure DONT cut them. Just zip tie them back please in case I buy your car next time around...lol Would like to have a chat with my PO about cutting wires as it is
