Finishing up Carb swap from TPI
Car: 1986 Trans Am
Engine: Carbed 355
Transmission: Th700R4
Axle/Gears: 3.73 Posi
Ok i have everything figured out besides the throttle cable bracket and the geometry corrector for my tv cable i have a holley 1850-4 600cfm vaccum secondaries and a 700R4 transmission, Im getting rid of my tpi throttle cable and tv cable and replacing them with cables from a factory carbed third gen. i just really need links or picture or just advice in general.
Re: Finishing up Carb swap from TPI
You can get brackets from Jeg's or Summit to handle the new throttle cables. When I did this on another car I just fabbed a bracket that mounted to a boss on the intake and then I cut out a square to mount the throttle cable to. Did not have the auto trans though. Just used a piece of heavy sheet metal, worked fine but not pretty ...
http://www.jegs.com/i/JEGS-Performan...ductId=1250058
Car: 1986 Trans Am
Engine: Carbed 355
If i knew how or had the tools to fab a bracket i would just to save some cash but i unforunatley dont lol.
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I messed with the cheap Mr. Gasket bracket on my car. Finally launched it in the woods and bought the CSR bracket and the extra adapter for the TV cable. I used the TCI geometry corrector. All of this worked with my stock TPI cables. However, I would like to ditch the throttle cable and get the shorter one for the carb equipped cars.
Received 1,668 Likes
Car: 1986 Trans Am
Engine: Carbed 355
There website is so confusing where do i go from that home screen?
Read the "TV 101" article; look for your carb in the liist at the left; open the catalog; stuff like that.
Car: 1986 Trans Am
Engine: Carbed 355
Ok i went ahead and got the geometry corrector from summit instead of tvmade easy because, it was cheaper and ive been reading it has worked for many people on here just fine. now i just need a tv cable and a throttle cable i cant seem to find where to get them at reasonable price? anybody have them that they would sell me or point me in the right direction where to buy?
86IROC112
08-17-2015 02:00 PM
Sanjay
08-12-2015 03:41 PM
