Tune carb for higher altitude?
Old 10-23-2011, 10:16 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey all, a couple months ago I moved from Florida to Colorado. Does the carb need to be tuned to account for the higher altitude? What would I need to tweak?
Old 10-24-2011, 02:07 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The computer carb does the primary retuning for you on the go.
If you haven't retuned the secondaries (rods/hanger, AV tension), then you'll probably benefit from that.
Old 10-31-2011, 07:21 PM
oil pan 4's Avatar
Car: 89 Firebird
Re: Tune carb for higher altitude?
What do you have for a carb?
When I moved from the eastern virginia to newmexico I went from "just running a little too rich" to drounding the engine in fuel.
Old 10-31-2011, 09:41 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Ignition timing needs to come back a few degrees.
Old 11-01-2011, 04:09 PM
five7kid's Avatar
Engine: LS1/LQ4
When you go to a higher altitude, you can usually get away with advancing it a few degrees from the factory low altitude setting since cylinder pressures will be a little lower. Backing it off a few degrees would be going the wrong way.
Old 11-01-2011, 06:15 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
I have a quadrajet. I haven't re-tuned the secondaries. Any suggestions on what rods/hanger I should go with?
Old 11-04-2011, 10:39 AM
Car: 1984 Z28
Engine: 454
Transmission: Th400
That was not the case for the car I use to drive when I lived in California. Maybe it was because I didn't rejet the carbs and the mixture was off at altitude. The car wouldn't run pull out on top end as good unless I backed it off.
Old 11-07-2011, 01:24 PM
five7kid's Avatar
Engine: LS1/LQ4
The DR rods are pretty good, if you can find them. Do you know which rods & hanger you have now?
Old 11-07-2011, 01:25 PM
five7kid's Avatar
Engine: LS1/LQ4
You had something else wrong.
GeneralIesrussi
Carburetors
01-20-2020 01:06 PM
Azrael91966669
25
06-20-2017 04:04 AM
andy74
09-03-2015 08:41 AM
UltRoadWarrior9
09-02-2015 08:24 PM
Quick Reply: Tune carb for higher altitude?
