carb V8 383
Old 11-01-2011, 06:26 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
carb V8 383
What carb do you recommend?
What Distributor and ignition
Any information would be useful!
___________________________
sorry my english sucks!
Old 11-01-2011, 09:27 AM
oil pan 4's Avatar
Car: 89 Firebird
Re: carb V8 383
http://www.edelbrock.com/automotive_...ers_manual.pdf
Old 11-03-2011, 07:40 PM
remltr's Avatar
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Re: carb V8 383
Cam,heads, intake?
Old 11-04-2011, 10:58 AM
Car: Camaro 1988
Re: carb V8 383
Originally Posted by remltr
Cam,heads, intake?
224/228 на 0,50 1500-6500(LT4 Camshaft),Vortec 062 ,Summit AIR GAP Stage 3!
Old 11-07-2011, 01:01 PM
86InfidelIrocZ's Avatar
Car: 86 IRoc
Engine: 383 @ 505hp 530ft/lb torque
Transmission: TH350
Axle/Gears: 10 Bolt and 2.73
Re: carb V8 383
A Holley 600 should be more then adequate. My vote hands down.
I recommend mechanical choke vacuum secondaries,
http://www.holley.com/0-1850C.asp
For the distributor I would go with the 65k HEI
I recommend http://www.skipwhiteperformance.com/...x?Item=6500-GY
Old 11-07-2011, 01:40 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
CID X maxRPM /3456 = required carb CFM for single plane intake. Add a little more for a dual plane intake.
That formula, using 383 CID and 6500 max RPMs, produces 720 CFM. So, go for 750 CFM.
Vacuum secondary carbs are for tow vehicles. If you put the package together properly, you won't have any problems with a double pumper carb.
The best thing you can say about Edelbrock carbs is they are shiny.
Old 11-07-2011, 01:51 PM
Car: 86 IRoc
Transmission: TH350
Re: carb V8 383
http://www.4secondsflat.com/Carb_CFM_Calculator.html
If you want to be accurate with it.
I'm running a 600 on mine. I'm 95% VE @ 5500 RPM (579.044 CFM).
I get ~500 hp and 530 ft/lb out of it. Worth every penny
Old 11-08-2011, 03:36 PM
five7kid's Avatar
Engine: LS1/LQ4
It's still ballparking. It doesn't mention intake type, and, as already mentioned, you typically need a slightly larger carb for a dual plane intake than you do for a single plane intake.
Do you have a dyno sheet for your engine? Did you run side-by-side comparisons with different carbs on the dyno to optimize your combo?
As the link does state, engines are a compromise. What might give you the best ET on the drag strip may be a pain to drive daily.
Old 11-10-2011, 11:19 PM
remltr's Avatar
Re: carb V8 383
Agreed. Listen to five7, he is a Guru!
Old 11-20-2011, 03:50 AM
Car: Camaro 1988
Re: carb V8 383
What can you say about the carburetor Speed Demon ?
Old 11-21-2011, 12:05 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: carb V8 383
I've seen a ton of people complain about metal shavings from initial machining being down in the carbs from Barry Grant causing bad performance issues. I've also seen some that worked just fine. If I were to buy one, I'd inspect it thoroughly before bolting in it based on what I've HEARD - but I've never owned one personally. Anyone I know prefers Holley or Edelbrock over a Demon carb, but they are opinions. You may find that you like them, who knows.
Old 11-26-2011, 05:41 AM
Car: Camaro 1988
Re: carb V8 383
They are better than Holly?
Old 11-30-2011, 11:53 AM
Car: Camaro 1988
Re: carb V8 383
this distributor good???
Old 12-05-2011, 06:56 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: carb V8 383
ive seen some bad reviews about skip white performance, but i havent used them first hand. that being said, it looks like a good unit and for only $49, its a steal. id check out the vender review forum about skip white performance before commiting to buy though.
WickedBowtie
Members Camaros
09-17-2015 09:13 AM
WickedBowtie
09-11-2015 11:24 PM
IroczFan
Carburetors
08-18-2015 05:19 AM
86TpiTransAm
Carburetors
55
03-28-2001 11:54 AM
Quick Reply: carb V8 383
