Swapping throttle plates
Old 11-05-2011, 12:10 AM
JLCustomizing's Avatar
Car: 1984 Trans Am
Engine: 5.7 Liter V8
Transmission: Auto 700R4
Axle/Gears: Stock
The carb im rebuilding has a lot of problems with the throttle plate so I figure it would be cheaper and easier to just find another one to swap over. Im rebuilding an 82 t/a 305 4bbl quadrajet carb and was wondering if this throttle plate would work. Its been rebushed already and since my throttle and secondary shafts have broken bolts in them and my throttle linkage is bent I was hoping this would bolt right up.
Old 11-07-2011, 01:30 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I assume that's an actual picture of the part you would be buying.
The only thing that comes to mind being different between computer and non-computer throttle plates are the threads of the idle mixture screws. But, I haven't done a side-by-side comparison of them, either.
That throttle arm looks weird. Can't see for sure in the pic, but the TV cable mount probably isn't correct.
Old 11-07-2011, 01:49 PM
Car: 1984 Trans Am
Axle/Gears: Stock
Re: Swapping throttle plates
Ill probably just send this one off to be redone. Almost all the screws in the shafts are broken off. Im guessing they could be drilled out and put new screws in but im going to send it off to be rebushed anyway so maybe ill just have them fix that problem as well.
Old 11-08-2011, 05:13 AM
DoubleV's Avatar
The non CCC throttle plates have a hole in them for the power piston to function. The CCC throttle plates don't have this hole, but it can be drilled.
When I compared my 83 CCC throttle plate to a 77 throttle plate, they were almost identical other than the hole and the 77 had easier access to the idle mixture screws. There might have been more differences, but I don't reacll.
Old 11-08-2011, 10:16 AM
five7kid's Avatar
Engine: LS1/LQ4
Probably a good choice.
1992 Trans Am
05-10-2023 07:19 PM
midge54
01-29-2017 07:00 PM
mdtoren
08-16-2015 05:45 PM
timonator
08-13-2015 11:27 PM
Quick Reply: Swapping throttle plates
