quadrajet choke wire
Old 11-30-2011, 04:00 PM
Cody302's Avatar
Car: 1984 Camaro Berlinetta
Engine: Chevy 305 4bb
Theres a blue wire coming off the choke on my Qadrajet. It hanisnt been connected since i got the car, im wondering where it goes to. I was told any power source but im not sre if im better off connecting it to the battery like they said at Advance or to the ignition coil.
Old 11-30-2011, 06:00 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
It is a dedicated circuit, energized by a relay inside the car.
http://austinthirdgen.org/mkportal/m...ine_wiring.gif
You don't want to connect it to the coil, as the choke thermostat coil will draw down power from the ignition. You don't want it connected to the battery, because then the choke would always be open, even when the engine itself is cold (whoever told you that should be banned from ever giving car repair advice again for the rest of their life). It needs to be connected to switched 12v source, and the way the factory did it keeps the choke thermostat from getting power unless the engine is running and the alternator charging the battery.
Old 11-30-2011, 08:39 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Re: quadrajet choke wire
Are you talking this blue wire? This wire is attached to the passenger side of the Q-Jet on my '86. It then disappears in to a wire loom.
Old 12-02-2011, 12:28 PM
Cody302's Avatar
Yes zz3 that is the one i am talking about. Im just not sure where i should run it to because it was cut when i got the car. Any ideas?
Old 12-02-2011, 01:16 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
To a switched +12v location. Theres a couple in your fuse block.
Old 12-02-2011, 07:24 PM
five7kid's Avatar
Engine: LS1/LQ4
Why not connect it back to where it is supposed to go?
http://www.team3rdgen.com/modules/3r.../1985_c100.gif
Old 12-03-2011, 11:33 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
probably got cut because of a malfunctioning relay...
Old 12-10-2011, 08:12 AM
eddie79's Avatar
Car: 91 Camaro RS
Engine: 355
Transmission: 700R4 RAPTOR
Axle/Gears: 373
just like installing any after market carb w electric choke it needs 12v. DO NOT HOOK IT TO THE DISTRIBUTOR ITS ONLY 9 VOLTS!!. it wont work right. holley recommends your windshield wiper motor, its 12v and comes on w/ the ign key.or get the haynes camaro book, and check the wiring diagram in the back pges.
Old 03-01-2015, 08:02 AM
siegelbeast's Avatar
I had the same problem and this helped but in the pic there is another plug coming out of the carb in the right of the pic where do these 2 wires go and what are they for thanks
Old 03-01-2015, 09:49 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Two wire connection is for the Mixture Control Solenoid (MCS) these wires come out of the ECM harness that originates from the passenger footwell (above hush panel) and enters the bay through the fender near the blower.
Choke wire comes out of the engine harness from the firewall connector near the brake booster.
Best to hook everything back up as it's supposed to be. Rather than hacking 'alternate' work arounds.
colton_carlson
03-08-2019 12:21 PM
Infested
05-22-2018 11:56 PM
ndndndnd
Carburetors
17
09-05-2015 06:24 PM
Thaney9
08-29-2015 03:16 PM
armybyrd
08-10-2015 09:23 PM
Quick Reply: quadrajet choke wire
