is there a carb that bolts to tbi?
Old 02-15-2012, 02:12 PM
raptercat92's Avatar
i cant seem to find a adapter plate that does tbi to carb, so im wondering if there is a carb that bolts directly on to a tbi bolt pattern?
Old 02-15-2012, 02:23 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: is there a carb that bolts to tbi?
There are lots of adapters to put a TBI on a carb intake. Some 2 bbl carbs might fit a TBI intake, but it'd hardly be a performance application.
Old 02-15-2012, 04:22 PM
not looking performance. looking to eliminate electronics
Old 02-15-2012, 04:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Even still, forget about a 2bbl carb. Change the intake and use a 4bbl.
Old 02-15-2012, 04:30 PM
1985WS6TA's Avatar
Car: 1985 WS6 Trans Am T-Top
Engine: 355 TPI N/A
Transmission: Borg/Warner T-5
Axle/Gears: 3:42
Why exactly are you getting rid of the TBI if you're not looking for performance?
Old 02-15-2012, 04:50 PM
eliminate electronics, dont wanna spend 250 on an intake then another XXX$ on a carb so does anyone know of a carb that would bolt to tbi?
Old 02-15-2012, 05:07 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Try a Holley 2300 with a 17-47 adapter. The adapter is made for something that makes sense though, so you'll have to modify it for what you're trying to do.
If it works, then I hope a $300 carb with a $100 adapter fits your "need".
Old 02-15-2012, 05:36 PM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
Why? May I ask?
Old 02-15-2012, 07:40 PM
makaveli09's Avatar
Engine: 350sbc
Transmission: TH700R4
just go a get a stock 4bbl intake and Q-jet and distributor at the junkyard.
that would do what you want for cheap.
Old 02-16-2012, 02:47 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Apeiron is right as this adapter is designed to go the other way and would need to be modified to work the other way. This could easily add much more expense if you can not do it right the first time.
The TBI is a three bolt pattern where carbs are four bolts so there would be no chance that I know of to find a three bolt carb.
Old 02-16-2012, 10:55 PM
for a 4.3?
Old 02-16-2012, 11:02 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
4.3s came with carbs too.
Old 02-17-2012, 12:04 AM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
What do you have with a 4.3 .? S-10?
Old 02-17-2012, 09:14 AM
Camaro-Drew's Avatar
Car: 92 rs Camaro
Engine: no engine now, some sorta sbc soon!
Transmission: none now, built auto oneday!
Axle/Gears: stock now, 9" one day!!
Seems to me that all the headaches of trying to frankenstien this set up is a lot harder to deal with than electronics that govern themselves.
Old 02-17-2012, 10:53 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i think a wire cutter intervention is in order here
Old 03-01-2012, 01:17 PM
what 4.3l came with a carb? mines from an 88 s10 i know that s10's gmc 1500's blazers astro vans... and a few others had 4.3's but none that i know of with a carb.
Old 03-01-2012, 01:25 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
1985-86 full size pickups and vans.
MustangBeater20
10-29-2022 09:20 PM
evilstuie
01-09-2020 08:29 PM
midge54
12-27-2019 04:14 PM
pimp2303
07-27-2017 02:03 PM
Dwayne614
09-28-2015 08:33 AM
Quick Reply: is there a carb that bolts to tbi?
