Holley fuel levels
Car: '82 Camaro '48 Pontiac Streamliner
Engine: 305ci (SUJ) Holley1850-3
Transmission: TM350
Axle/Gears: Stock
Holley fuel levels
My Holley 1830-3 has both float valve screws all the way down but fuel still runs out of the level plug holes with the engine stopped and the pump running.
Are there different lengths? They don't seem worn.
Re: Holley fuel levels
Just a couple of things to consider.
Remove the bowls and make sure that the floats move freely. Also, make sure that the floats aren't leaking (filled with fuel).
The external float adjustment may not have enough adjustment range because the float arm is bent.
http://forums.holley.com/entry.php?4...el-Carburetors
Car: 1986 Trans Am
Engine: 383 Stroker
Transmission: LT1 T-56
Do you have your pressure regulator set at the right pressure?
Transmission: TM350
Axle/Gears: Stock
Not sure where the pressure regulator is.
When the chamber is off, the float when up is about 15 degrees above level.
The float seems empty.
It looks like the jets are too short.
Does the engine need to be running?
Car: 1986 Trans Am
Engine: 383 Stroker
If you are running a electric fuel pump you should have a regulator. I would get a fuel pressure gauge and check your pressure. A Holley carb should not have much more than 7psi. You may have to much pressure and the needle and seat can't stop the fuel flow when it reaches the proper fuel level.
Transmission: TM350
Axle/Gears: Stock
I got it now. I had not understood how the adjustment actually worked. Should it be done while the engine is running or static?
Transmission: TM350
Axle/Gears: Stock
Should there be an adaptor plate (pn 20-121) for the th300? It is connected directly at the moment.
9192camaro
16
02-03-2019 12:21 AM
86IROC112
08-17-2015 02:00 PM
