Holley Carb
Holley Carb
Has anybody had look with rebuilding a holley carb?
Model-#4175, 650 cfm, spreadbore.
http://www.summitracing.com/parts/hly-37-396
this is the kit I was recommended to buy.
Just got a 86 and tuning the engine up, wanting to clean all the ports up on intake and change intake gaskets, clean carb up soak & rebuild kit, and change valve covers and gaskets.
Any suggestions, thanks in advance
Re: Holley Carb
they're not too hard to rebuild.
i'm not too sure that you picked out the correct rebuild kit though? i know you cant go by pics, but that looks like a kit for a 2 barrel?
maybe one of these is more correct?
http://www.summitracing.com/search/b...4%2B4294921778
Re: Holley Carb
Re: Holley Carb
do you have any pics or part numbers? that would help identify what ya got.
i suggest buying a book on rebuilding/tuning/tricking holley carbs. most auto parts stores or book stores have them fairly cheap. write down the changes you make for future reference in the book.
theres also a good thread/sticky on here by Sofa about tuning holleys.
valvecovers are personal prefference i suppose.
are you saying that your planning on gasket matching the intake to the heads by "cleaning up the ports" ? or a suspected vacuum leak? etc?
sreZ28
10-22-2015 08:21 AM
