Please help indentifing carb
Car: Siverado SS, IROC-Z
Engine: 6.0/5.0
Transmission: 4L60E/T5
Axle/Gears: 4.10/3.73
I've got a carb I'm having some trouble identifying. Ill describe as best as I can. Has HP main body with screw in bleeds P 28 nozzle and S 31 nozzle, pink cams. NO list number!! Base plate has "11196" stamped and "12R.11196.1B" cast in it. 1.25 in Venturi at narrowest point and 1 9/16 throttle bore. Primary side has center hung float, metering block has 66 jets 6.5 PV. "8485" stamped and "1947" "3" cast. Secondary side has center hung float, metering block has 66 jets 6.5 PV and has "10884" stamped in it. This carb was advertised as a 4776 600 Cfm DP HP by the rebuilder. Any help would be greatly appreciated. Thanks
Engine: 6.0/5.0
Re: Please help indentifing carb
Forgot to add four corner idle and no vacuum ports whatsoever
Engine: 6.0/5.0
Just for future reference for others. Took carb to a local carb shop. He took some measurements and confirmed that the carb is a 600HP.
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
