Replacing Factory Quadrajet w/ Jet Performance
Car: 83 Z28, 84 Z28
Engine: 5.0 Cross Fire, 5.0 H.O.
Transmission: 4 Speed Auto, 5 Speed Manual
Hey everyone, I am looking for a bolt on replacement for my old tired factory quadrajet. I am looking to stick with a computer controlled carb and I have been exploring my options. I have been focusing in on Jet Performance Quadrajets but I am trying to figure out which one will work for my application and be truly bolt on... and if it is even a good idea. I am looking at the stage 2 options. My application is for a 1984 5.0 H.O. nothing too fancy, accell ignition and edelbrock headders.
Which would be the correct computer controlled carb?
Part # 32002
Part # 32102
Part # 35002
http://www.jetchip.com/Shop/shopdisp...pp=10&catID=36
thanks a lot for any help you can offer. Also, would these carbs come with all of the required connectors, or would they have to be removed from the old carb?
Part # 32002
Part # 32102
Part # 35002
Received 1,671 Likes
Re: Replacing Factory Quadrajet w/ Jet Performance
None of those appear to be computer-controlled, and none are for Chevy. (fuel line setup in particular is different)
I don't see anything on their page that's what you're looking for. I'd suggest waiting til they're open, and giving em a call.
FWIW I had my electronic quadrajet re-built by a guy here in NH,cost about $100,one week turn around and starts runs 100% better.
I had my CC Qjet done by Cliff Ruggles at cliffshighperformance.com He's a specialist in the Qjet world.
If your motor is stock, a stage one is all you need. Only go with a stage 2 if you plan on upgrading the motor later on. If you have Cliff build it, just talk to him on the phone and he'll hook you up.
You will need a C Qjet and as Sofa indicated, none of those are.
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I agree on getting the Q-Jet rebuilt. Make sure you have the throttle shaft bore checked, and the well plugs taken care of.
