Mixture/TPS readings on autoxray question
Old 07-02-2015, 09:49 PM
Chuck84TA's Avatar
Car: 1984 Trans Am Recaro Edition
Engine: 355 L98 Vortec 226/234 custom cam
Transmission: TKO-600
Axle/Gears: On borrowed time...
Are these readings normal for closed loop idle? Car is a manual 5spd.
I think the mixture should be 50%? Where should the throttle be?
Old 07-03-2015, 10:10 AM
naf
naf's Avatar
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Mixture/TPS readings on autoxray question
My 84 LG4 does not want to show the correct dwell on my autoxray 6000. I have to break out the old dwell meter on that one for some reason.
Otherwise the TPS could be set closer to 0.40 but it's not too far out of line where it's at.
You want to see closed loop and be able to see the rich/lean flag bounce back and forth. Dwell near 50%, it will swing around some.
Old 07-03-2015, 10:32 AM
Chuck84TA's Avatar
So the "Mixture Control" readout that reads in % is the same as dwell?
Should t my vacuum also be higher? It's a rebuilt carb and I double/triple checked the connections and bolts
Old 07-05-2015, 09:18 AM
naf
naf's Avatar
yes. mixture control is the dwell. percentage of time the rods are down, restricting flow.
vacuum may be somewhat low due to your cam. not terrible though.
you may have some nozzle drip at idle with the 350 and cam, unless your carb was modified with enlarged air bleeds. no big deal, although it may make the idle rougher. you may have to screw in your mixture screws some to compensate and get a good, near 50% mixture setting.
Old 07-05-2015, 07:26 PM
Chuck84TA's Avatar
I'll try that, thanks Naf!
Ghettobird52
12-29-2023 08:23 AM
ezobens
08-19-2015 10:29 PM
redmaroz
08-16-2015 11:40 PM
bamaboy0323
08-15-2015 07:20 AM
reiderz iroc
08-13-2015 04:57 PM
Quick Reply: Mixture/TPS readings on autoxray question
