Snipe Hunt? AU 2nd rods, J code 2nd hanger
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Guy offering tips on my V8 carb tuning, suggest I find some AU secondary metering rods, and a J code secondary metering rod hanger.
I can find everything but that???
Am I on a snipe hunt????
Re: Snipe Hunt? AU 2nd rods, J code 2nd hanger
Might try your local GM dealer, which is where I purchased my DR rods and G hanger (though several years ago).
EDIT: The following may assist as AU rod specs are provided:
http://www.hioutput.com/tech/qjetrod.html
JamesC
JamesC
Give Cliff Ruggles a call. Dude is a Qjet guru and has written several books.
Cliffs High Performance
He may even answer the phone. He build my factory cc Qjet to handled my 355.
Received 1,666 Likes
Not sure what the big deal about hangers is... just bend what ya got. Measure em first so you know where you're starting out.
They're a tuning tool anyway; any ones you might get, might or might not be just exactly perfect for your setup, in which case you would ... you would ..... unnnngggggghhhh ..... ,, .. ,,,, ..... ummmm, what?
Bend em.
Don't outsmart yourself over something THAT dirt simple.
Bend em.
Wow, my little QJet secondary rod spreadsheet sure has made the rounds over the years!
I wouldn't bend a QJet secondary hanger when you can buy new ones for so little. Here's a K hanger- just one letter (a few thousandths of an inch) away from the J you're looking for:
http://www.summitracing.com/parts/je...FQ2QHwodmokCYA
You can get them cheaper than that if you look around.
Start out with a set of DR secondary rods almost always. They work great 90% of the time and you can still buy them, to my knowlege, from GM. Part number is in the spreadsheet. Remember they are typically sold individually so you need to make sure you are getting two.
Car: 83 firebird
Transmission: 700
I got lots of parts from a bunch of cars that were on the way to the crusher. grabbed all the carbs I could. big blocks, small blocks Buick Chev Olds and Pontiac. lots of different parts to work with.
BumpaD82
02-26-2016 02:57 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
