going from tbi to carb
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: going from tbi to carb
Do some searching on the forum and read about what other people have done. It will give you an idea of what you are up against. You will need a fuel pressure regulator that will work with the return line. You will also need a non-computer controlled distributor ( I like the gm performance HEI). You don't mention which trans you currently have. If it is a 700R4 automatic, you will need a way to lock up the converter and also a geometry corrector for the carb where the TV cable will hook.
Billy Decker
09-04-2015 03:46 PM
