What's the best way to route the return line/regulator/electric pump?
Old 11-21-2015, 12:52 PM
Drone358's Avatar
Using the original fuel pump in the 92 RS for my carbed motor. I've seen a few different ways to route the regulator and the supply/return lines. Curious of what yall have done, any Info is helpful thanks guys.
Old 11-21-2015, 10:33 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Re: What's the best way to route the return line/regulator/electric pump?
Look through the sticky above with pics of carb'd engines. Many with such setups in there.
Old 12-24-2015, 11:11 AM
usmechanix's Avatar
Car: '91 RS Camaro
Engine: Custom Small Journal 327
Transmission: T-5 5 Speed
Axle/Gears: GM 10 Bolt 3.08
I'm curious about this too. (91 RS 305) slamming in a 327 carbed engine next fall, unfortunately the pics I referenced really weren't all that much help... running a 750 quick fuel slayer series carb with dual inlet.
Last edited by usmechanix; 12-24-2015 at 11:12 AM. Reason: didn't have enough info
Old 12-31-2015, 06:53 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I made a simple bracket to mount the regulator on. Bolts to the driver's side strut mount. Had lines made from the existing fuel lines to the regulator. Then run rubber hose to the carb. Quick and easy.
Old 01-05-2016, 08:48 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
I agree. The pics were ok, but not of just their reg/ret set up.
GeneralIesrussi
01-22-2018 01:19 AM
3rdGenBirdOwner
03-03-2016 09:03 PM
Drone358
01-16-2016 07:48 AM
igende
11-12-2015 05:03 PM
Gunsbee
10-25-2015 08:54 PM
Quick Reply: What's the best way to route the return line/regulator/electric pump?
