cc quad to non
Car: 1990 Formula
cc quad to non
I have a 305, automatic, 87 formula computer controlled quad. Going to block off the egr, put an older HEI distributor, and put on an older non cc quad on the stock intake. Should I just unplug the ecm, or leave it plugged in and take the light out of the SES? (I'm assuming the SES will stay on). I guess the cruise control will not function if the ecm is unplugged? Haven't found on here if it will work or not. I did see that the tranny lock will not work. If I leave the ecm plugged will it cause any problems? Thanks!
1 Post
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: cc quad to non
Eclers corvette Sells a plug and play torque converter lock up switch.it's only $89 and you don't have to drop your tranny pan.It has the factory connectors.you can dial in what speed you want the converter to lock.It's so easy even a clutz like me can put it in.No cutting of wires just plug it in.
Car: 1984 15th Anniversary Trans am
Engine: 305 HO (L69)
Axle/Gears: 10 bolt posi with 3.73 gears
Re: cc quad to non
I literally just finished doing the same swap except I kept the EGR hooked up.
This is the switch you are talking about right?
http://www.ecklerscorvette.com/corve...1982-1991.html
I feel like I am going to need to order one. What happens when the trans does not receive a signal to lock up the converter? Does it just not go into overdrive or what?
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Re: cc quad to non
that kit looks the goods. Steve, how long do you think it took to put in? and the difficulty rating on a 1/10 scale (1 being easy - 10 being near impossible)
Sean Brereton
09-28-2023 10:04 PM
Z28 Boy
Aftermarket Product Review
12-01-2000 07:47 AM
