twin turbo carb
twin turbo carb
Hi folks
I need some advise on what size blow through carb to use on my 1986 Camaro. It has a fresh build 350 with a .495 lift roller cam, lifters and rockers. Heads are cast and have been ported and polished. Standard pistons and crank. I have installed two t3 turbos and am getting ready to purchase a blow through carb to accommodate the setup. I looked at the FITech efi but am leaning towards a carb set up. It has a 700r4 with positraction 4:11 gears (10 bolt). All electronics including ECU with wiring has been removed as well as the A/C. Your recommendation will be helpful and thanks
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: twin turbo carb
There was a nice Holley 650 built for blow through application in the classified section. I would buy that. Plenty of carb for what you are doing.
chevguy727
05-04-2016 05:16 PM
