Which hoses to keep?
Old 09-24-2016, 06:27 PM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
I noticed I have multiple vacuum hoses that are cracked or disconnected, I am doing a little tune up tomorrow and might as well get the hoses replaced. I am wondering exactly which hoses to keep connected. I was planning to keep PCV and the Dizzy vac retard and cap everything else. I am going to be getting rid of the EGR and EVAP equipment and see no use in replacing their hoses.
Old 09-29-2016, 05:00 PM
JTV
JTV's Avatar
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
Re: Which hoses to keep?
LMK how this goes. I want to start taking off emission equipment and didn't want to have car running poorly. Thanks.
Old 10-08-2016, 12:16 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
I've removed most connections as you were saying, but I kept the purge canister hooked up to vent the fuel tank.
So I have PB booster, dist (direct to carb), PCV, and canister. Also, don't forget vacuum to your heater/AC actuator. It goes into the firewall. Yours is older than mine, it may be cables(?).
b2010
09-28-2016 07:28 PM
Faine
Camaros Wanted
09-21-2016 07:50 PM
1982firebird7
Wheels and Tires
09-21-2016 03:41 AM
T.L.
09-12-2016 09:10 PM
h1-vltg
09-04-2016 09:51 PM
Quick Reply: Which hoses to keep?
