fuel filter?
Old 07-30-2007, 09:03 PM
bigdaddy89's Avatar
fuel filter?
i have a 91 z28 camaro convertable rally sport, and im haning trouble finding the fuel filter. can any one tell me where it is?
Old 07-30-2007, 09:15 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Re: fuel filter?
is it a carb or fuel injection?
Old 07-30-2007, 09:18 PM
Formulabruce's Avatar
Re: fuel filter?
Its up under the drivers side rear axle on the body. need car up some to really look at/access it.
Old 07-31-2007, 02:10 AM
bigdaddy89's Avatar
Re: fuel filter?
fuel injection
Old 07-31-2007, 09:51 PM
1991 Vert's Avatar
Car: 2002 TA, 1991 TA
Engine: V8
Re: fuel filter?
I was trying to get that fuel filter today but I was unable to get it loose. I was afraid to break the fuel line. I was trying to unscrew the the nut away from the filter, but nothing. I'm doing something wrong? Is there a trick to do this? Thanks in advance, Orville
Old 08-05-2007, 03:08 PM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: fuel filter?
PB blaster is your friend. Your car is about 16y.o so some rust is going to happen. Worst comes to worst, you might have to replace the fuel line. If you do, coat it in POR-15 or similar at the ends. If you have to replace the line, I pray for your mental health that the underside of your car isn't completely rusted out. I had to replace a brake line on my formula (which is the rust mobile. The carpet is keeping my feet from the pavement at 60mph) To be honest, I would much rather light myself on fire and jump in a pool of solidified gelatin than replace the brake line on that car again.
If you can't coat in por-15 when you get it off (which normally you wont be able to if it's still on the car, due to surface prep issues) then you can surround both ends with aquarium sealant. It will hold up on the road, but can be peeled off when you need to change the filter again.
Old 08-22-2007, 06:47 PM
bigdaddy89's Avatar
Re: fuel filter?
well i had to kindas wiggle it a little to get it out.. and i dident harm the fuel line
92camaroJoe
07-29-2023 07:57 PM
1992 Trans Am
05-10-2023 07:19 PM
specialized
06-18-2022 09:26 AM
Infested
05-22-2018 11:56 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: fuel filter?
