where to find the right t-top weatherstrips?
hi,
I have a problem in my car and with my t-top's.
I like to buy a new weatherstrips to my car, but here in Finland they don't understand what are the right weatherstrips into my car.
Could someboby help me!
I haven't vin code to my car, because this option code blanket isn't in the right place in the glovebox. (Sorry my english!)
What is this t-top model? Were could I finf the right weatherstrips to the body and sunroof?
My car year model is 1987 (H).
Here is one picture: http://www.nic.fi/~ilku/gta5.html
and here is my weatherstrip problem (you can see that SoffSeal weatherstrips doesn't fit to my car. What are the right weatherstrips?): http://forum.f-bodyfinland.com/Yabbs...topic=1126.645
Thank you,
Ilku
Thank you,
Ilku
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: where to find the right t-top weatherstrips?
Look at your Tops, if they have "C&C" on them then you need the C&C style seals... I THink Hawks thirdgen parts has the seals but I am not sure...
SoftSeal or a GM seal will NOT work as the T-tops on your car are actually an aftermarket conversion.
John
John
http://www.hawksthirdgenparts.com/in...ROD&ProdID=164
and this:
http://www.hawksthirdgenparts.com/in...ROD&ProdID=165
What does this "Car & Concepts" means?
Ilku
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
cars & concepts is just the name of a company that did aftermarket " T " top conversions . good luck .
Cars & Concepts was a company located West of Detroit Between Novi and US-23 off of I-96. C&C did many conversions for Ford & GM, they actually made the 1988 Banchee Prototype for Pontiac, and I believe they did the Olds Cutlass Verts for GM in the 90's, I belive they also did the Convertible conversions for Ford on the 80's Mustang. IIRC they did some Pontiac Fiero Convertibles too... In short they were not a small company and they were very similar to ASC in function.
Interestingly C&C also made T-tops for several other models:
Firebird & Camaro - 1973 - 1981, 82+
Monte Carlo, Cutlas, Regal, Grand Prix 78 - 83
Mustang & Capri 79 - 93
Dodge Aspen, Plymouth Volare 77 - 80
Dodge Mirada, Chrysler Cordoba 80 - 83
My info stops at 1983
ALSO they made a Notchback hatch for our cars way before the 88 GTA offered it.
John
John
Car: 91 Z28
Engine: 6.0 LSX 88 Turbo, EFI E85
Transmission: Glide
Axle/Gears: Strange 3:73 9"
Yes, you are correct, I was a C&C dealer for years and did T-tops, they are C&C units, I know C&C had been bought out and have not done T-Tops for many years, I remember that their seals were much cheaper than GM's as we serviced both. Finding the seals now, not sure...good luck...also they did the aerocoupe monte carlos as well....Rob
Car: 1988 Trans AM GTA
Transmission: 700r4 with shift kit
Axle/Gears: Stock
Mine leak right now and I look forward to getting new ones.
http://www.hawksthirdgenparts.com/t-...stripping-kit/
or try
http://www.sunroofdoctor.com/8292f.htm
I would call them first, before you order, to get all the parts you need.
or try
ambainb
04-25-2016 09:21 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
