Spoiler gasket
Old 01-24-2008, 06:26 PM
Crouchman's Avatar
Car: 1988 Iroc convertible
Engine: 305TPI
Transmission: T-5, swapped it in.
Axle/Gears: no clue, but I'll learn
Spoiler gasket
Are there aftermarket gaskets available for under the middle portion of the rear spoiler? Not called gaskets, but I'm blanking on what they're actually called. I've looked without any luck. Thanks!
GM calls this an insulator, it goes under the front edge of the center spoiler section on the convert to keep the water from going under the spoiler and into the trunk. Also called a gasket, filler and seal.
Old 01-25-2008, 09:46 PM
Dennis-Z28's Avatar
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
Re: Spoiler gasket
I need it too. Mine is there but shrank about 4" in length over the years.
Old 02-20-2009, 07:32 PM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Re: Spoiler gasket
I need one too Spoiler Insulator P/N 12331868
Old 02-21-2009, 07:51 AM
jnman's Avatar
Car: 87 Iroc Z Convertible
Engine: 305 LG4
Transmission: 700 R4
Re: Spoiler gasket
I need to locate one also! The one on my car has drawn up on either end.
Old 03-12-2009, 06:08 PM
mikeiaz's Avatar
Re: Spoiler gasket
u won't find one - here are 2 options:
1. coat the underside of the front lip with thin silicone sealer, spread flat and thin, let dry then mount the spoiler
2. 3M (and maybe others ) makes a wide, clear plastic adhesive "body protectant" film (various widths) - get a roll, trim a piece to fit the underside of front of spoiler, stick on, put spoiler back on
Old 03-14-2009, 05:33 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Re: Spoiler gasket
very nice
Old 03-31-2011, 10:40 AM
camarodriver15's Avatar
Re: Spoiler gasket
i know this is old but just to help anyone still looking for them i found some
http://www.hawksthirdgenparts.com/rearspoilers.aspx at the very bottom of the page 10 bux for the pair
Old 03-31-2011, 03:30 PM
my82roc's Avatar
Car: 89 Iroc Convertible
Re: Spoiler gasket
Those are for the 91-92 high rise spoiler.Wont work on a vert spoiler
Old 03-31-2011, 06:37 PM
Re: Spoiler gasket
sorry i didnt pay attention i came across this searching for those and thought thats what you needed my appologies
Old 04-07-2011, 12:38 PM
topless87's Avatar
Car: 1987 IROC-Z Convertable
Transmission: 5 Speed BW T-5
Axle/Gears: 3.08 Posi
Re: Spoiler gasket
I am currently repainting my 87 'vert and its spoiler "gasket" was creeping all over the place too so we are using Fender Welting that is for older cars. Looks the same, has a little longer lip but it is covered up by the spoiler anyway so you never will know. Just some info from someone else that is trying to make it right again.
Old 04-07-2011, 08:24 PM
chris lo's Avatar
Car: 92 z28 vert
Engine: ls6
Transmission: t56 magnum
Axle/Gears: moser 9 inch 4.11
Re: Spoiler gasket
man that is one hell of an idea i knew that i have seen something like the stock stuff before but i could not remember what it was i have been trying to remember for the last 3 months i am going this weekend to pick up a roll thanks, chris
Old 04-08-2011, 08:04 AM
topless87's Avatar
Re: Spoiler gasket
Anything to help my third gen buddies. :-)
Old 04-05-2017, 12:13 AM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
Re: Spoiler gasket
Reviving this thread since it's relevant.
http://www.classicindustries.com/product/camaro/parts/1668047a.html
hope this helps
Old 04-06-2017, 04:24 PM
madness's Avatar
Engine: 5.0 TPI
Re: Spoiler gasket
I purchased what is called extruded P-seal rubber which is what ASC seemed to use from www.elasostar.com its pretty inexpensive and easy just slit every two to three inches so that it curves. I used my old one as a template.
Old 08-04-2017, 09:31 AM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Spoiler gasket
Where did you purchase that from? The link provided is dead.
Old 08-04-2017, 09:33 AM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
I've been looking at different fender welting for that purpose. Any way you can post a picture of how your's turned out?
Old 08-04-2017, 09:36 AM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
Got it! http://elastostar.com/products/extru...seals-gaskets/
Old 08-09-2017, 02:54 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
Just an FYI, I contacted Elastostar. They can make the exact dimension insulator, but they need a minimum order of 100 feet. $175 for tooling and $175 for 100 feet of it, so $350 total
If enough of us are interested it could be done. This might be something for Lon or Hawks to look into. In fact, I should PM Lon.
Old 08-09-2017, 03:15 PM
madness's Avatar
Engine: 5.0 TPI
Re: Spoiler gasket
Chazman, sorry for the late response I was told the same thing about the 100' minimum but I spoke with a gentleman with a heavy foreign accent and asked for a sample and he charged me $ 1.50 per foot. The P portion was solid though not hollow like the link shows. Anyhow the bolts to my spoiler broke again and I took it to my body shop to have the bolts properly glued and they misplaced the gasket. So I'm stuck again without one and when I called I got the same message about a minimum order? There has to be some place that has it in stock?
Old 08-09-2017, 03:32 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
It sounds like we talked to the same guy. Last week he said I needed a 50' minimum. Today it's 100'. BTW, the bead is supposed to be solid.
Also, he referred me to one of his vendors and I ordered 6 feet of the closest rubber seal. It's perfect, except for the bead which is 1/4" - double the required size.
Old 08-09-2017, 03:43 PM
madness's Avatar
Engine: 5.0 TPI
Re: Spoiler gasket
I just spoke to a gentleman who said I could find some at www.mcmaster.com ? If you go to www.trimlok.com they have one for sale that may work. Its 2199 series and they want $162.25 plus shipping for 250' of it? If enough of us go in on something like that were are looking 8 to 10 dollars each for a 10 foot section if 25 of us go in? I'm looking at the McMaster website first guy said I would find it there?
Old 08-09-2017, 03:55 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
McMaster is who I ordered from. I just told him today, McMaster doesn't have the exact size. I'll check out the other one.
Old 08-09-2017, 03:59 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
Yeah, that 2199 has a bead which is much too large.
Old 08-09-2017, 05:25 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
I ordered a few samples today. Probably smarter than buying 6 feet at a time.
I have a feeling that between madness and myself we'll find something.
Old 08-14-2017, 01:51 PM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
You guys need to think outside the box...
https://www.thirdgen.org/forums/body...aired-fyi.html
Old 08-14-2017, 10:35 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
That Plasti-Mend looks interesting.
But a proper isolator/welting under the spoiler completes the factory look.
Old 08-22-2017, 11:01 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
I have received various samples from various companies. Not quite there yet.
Old 10-23-2017, 10:38 PM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
Re: Spoiler gasket
Any updates ?
Old 10-24-2017, 09:05 AM
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
I'd be in for a group buy if we need a certain minimum.
Can anyone post a good pic of the material itself? Did some searching didn't find anything.
Here's P-Seal. Wouldn't be surprised to find some at a local hardware store
https://www.google.com/search?q=p-se...w=1536&bih=960
This looks close:
https://www.google.com/search?q=p-se...xpY39xAFIBmBM:
Old 10-24-2017, 09:22 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Spoiler gasket
I still have the part under the center of my 92 Trans am vert if anyone needs a picture. Like every other one, mine has shrunk as well
Old 10-24-2017, 04:04 PM
my82roc's Avatar
Re: Spoiler gasket
I have a couple of them that came off of junkyard convertibles.
Old 10-24-2017, 04:53 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
https://www.ebay.com/itm/Fender-Welt...53.m1438.l2649
Out of all the samples I've gotten, I think this is the closest. The solid bead is not a "P seal", but I'd imagine it would work. The width would have to be trimmed a bit.
Old 10-24-2017, 06:14 PM
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
What do you mean by trim the width?
Old 10-24-2017, 06:15 PM
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
And if someone could post a pic that would be great.
Old 10-24-2017, 06:19 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
From the front of the bead to the end of it. Off the top of my head should be 3/4 of an inch, but this one is over an inch. It probably would fit under the spoiler without anyone knowing though.
Old 10-24-2017, 06:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
I've got a used one. I'll post pics later.
Old 10-24-2017, 07:11 PM
Engine: 350 carb
Re: Spoiler gasket
Put me down for a group purchase if we get one done.
Old 10-24-2017, 07:53 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Spoiler gasket
Put me down for a couple if we do a group purchase.
Old 11-01-2017, 09:25 AM
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
PICS?!
Old 11-02-2017, 12:51 PM
Engine: 350 TPI L98
Transmission: WC T5
Re: Spoiler gasket
Come on. Pics so we can order this stuff!
Old 11-02-2017, 02:49 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Re: Spoiler gasket
I recommend neoprene rubber, and cut my own to fit. I used .093 thickness. They used to offer samples for $10 shipped, but no longer. 36" x 36" sheet will cost $34.
http://www.americanmaterialsupply.co...10&or=16013739
Pics here: https://www.thirdgen.org/forums/body...y-paint-2.html
sheachopper
07-31-2019 11:27 AM
sp8ty
South East Region
09-24-2018 03:55 PM
F-body-fan
11-04-2015 06:13 AM
sp8ty
Exterior Parts Wanted
10-23-2015 08:35 AM
TP355Z
10-21-2015 01:05 AM
Quick Reply: Spoiler gasket
